do it nick i have to be up at 6 but i dont get up till 7.30 and get in the car roll down the hill 2 streets and get there still asleep opening up
stay talk grab a drink
If I had more beer I'd grab on but I'm all out and I don't feel like making a mixed drink... I'm content.
No I'm not a vampire but I feel like one sometimes, I sleep all day because I hate the sun light... My hands are always shakin body's always acheing and the dark is we're i feed, I could lure any women that I wanted to in my bed, with me.
And whiskey seems to be my holly water, mothers better lock your doors and hide your daughters
Write an essay next time
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
