I am also lost.
Sometimes he's a toy. Sometimes he's a pillow. Sometimes he's my chauffeur. Sometimes he's my pt. sometimes he makes me food like a good woman. I love him very much.
Well it's nice to see a happy couple
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
