What's the plan for oil and water lines? gonna get the makita out and tap that shit yourself? Going stock lines or braided?
Was reading over Dans thread and he used the heater hoses and oil was from one of the lines from the oil filter relocation kit.
Ahh I see. The toit method, like it. How do n/a injectors compare to turbo ones? Do you need the turbo ecu too?
Toit?
Will need turbo injectors and better fuel pump. Wanted to get the bulkier, harder to find peices first.
Ecu- nistune. :)
Toit?
Ecu- nistune. :)
Sorry. Slang for tightass among my mates haha.
Yeah fair enough. I reckon all those odds and ends are going to end up costing just as much as a whole new engine :s people want silly money for r34 turbos in particular. Did you see the hiflowed 34 turbo in the four sale section? Only 600. Pretty good considering a stock one will probably cost 300
Hey all. First post this weekend I think. Did so much to Kathryn's ute
Spent 6 hours trying to get one side of the upper control arm out.
Put it back together do the other side should only take about 2 to do now I know how to do it and have the right tool
Then the ball joints. Swap the pian arm for the right one tomorrow
And gearbox back in tomorrow after a rebuild
Hahah verrrry verrrrrrrrry productive weekend and verry tiring
Makes sense.
I've worked out that this should all cost about $1500 (as a rough estimate). The majority of parts purchased can be bolted on to the DET block if we go down that path in the future. Saw the high flow and was very interested... We are also doing this on strict numbers as it really is Chants project.
Makes sense.
fair enough.
fair enough.
Planning to do this more as a staged project. It does mean that you get a few extra parts along the way but means that it's drive able more often.
Part 1 - factory turbo RB25DE+T
Gather most of the main parts and get her going
Part 2 - 30 bottom end
Past 3 - 25/30DET with 3076.
cool should be good in the end
This is so true!
Though I will say the chosen method seems likely to give you more pains in the ass than normal but Anna and I learned a hell of a lot form our pain in the ass project that could have been done easier.
There's almost always a better way to do things. Taken a look at practicality, cost, ease, cost, cost etc this seems to work.
Are you talking about the 32 gtst?
I actually dont think it will work from an ease point of view and also quite possibly a cost point of view (Have seen whole NEOs go for 1100 ish) but after you are done you will know a whole lot more about the car which is good.
Nah not so much the R32, it was a series of unfortunate events and shit workshops. The Sil80 was the one where we spent endless time screwing around trying to get factory bits to work ect ect. Not lots of money, just countless hours finding parts lol
Well I've been stuck with trying to figure out this GameCube emulator.....nothing is easy when it comes to me and computers. I'm not a god damn IT specialist!!! GRrrrrrrrrrrr!!!!!!
I hate computers with a passion~
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
