Which scotch? Laphroig sounds appropriate..
Never tried it TBH. I have Bowmore at home I wonder how would compare to Laphroig considering the similarities (location) of the distilleries.
Cool. I agree run in ks are going to be annoying. But at least I will be able to drive my car unlike now where I cant do fkn anything.
they are shit, but having mountains nearby is good, the constant load and rpm changes are really good for run ins, where as dawdling up and down the freeway is not
mountains it is then.
