I purchased Tomei crate engine back in Nov last year and most of the parts within the last six months
Sorry for all the questions, just trying to piece the story together, what made you take it off the road 2.5 years ago?
will be good to see what it really does after engine has been run in.
I have a mate with the same turbos and ECU and he made 470hp at the wheels on a stock motor, you should make at the very least that amount
I wanted to change the turbos as the nismo turbines were stuffed! I proceeded to do it myself (done it before). Then one thing led to another and decided to restore and build it. I already an N1 block, CP pistons, oil pump and engine mounts ready for rebuild. But Tomei crate engine was very hard to turn down for what it had to offer.
Ps If you had have sent the car and engine to Jase and I in November we could have had the car back to you that weekend :P
don't get me started. Gav sent me via tex MSG last nite an apology and then called me this morning to apologize again for the delay.
Ahh i see! Fair enough!
And so he bloody should apologise! No one pays upfront, and when you do you expect speedy service
can't wait mate. It should get close to the 400kw mark...............well that's benchmark I have set but I want the car to more reliable than anything else. So I'd be happy with 380rwkw.
400kw will be possible on 98, but that will be sort of the limit, it would piss it in on E85 though!
nailed it! Doesn't take rocket scientist to work that one out. He said to me he was sorry and that he needed a good kick in the backside (his own words). I've had more care from him within the last 24hrs than since I had given him the car!
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
    • Yeah - I mean, go the other way. Smaller range. Not larger.
    • To re-cap, I bought: https://www.alibaba.com/product-detail/Lsailt-8G-Infiniti-Q50-Q60-2014_1601171829627.html?spm=a2756.trade-list-buyer.0.0.2cd476e9FTIlKE As you can see, if I bought 20 it was $653, but I bought 1 so it was $1,170. I was very tempted to buy 2 and resell 1 at 25% cheaper. @MBS206, I am not sure if they do a Kluger one, here is their list but it might be there under a global model name: http://www.lsailt.com/product/android-interface?page=1 Keep in mind these full android replacements have basically all the bits a phone does (cpu, ram, storage, wifi, bluetooth, usb interfaces) other than a screen (it uses a host), thus the $800+ cost. Android Auto screen mirroring is MUCH cheaper as it's just a cut down shell, input mirroring and output mirroring BTW I also need that "screen off" feature, it is much harder to see wildlife even if a dash is reasonably dark. Both the Fuga and V37 have display off buttons for night use, they just come back on for a second or 3 if you interact with it, eg skip a song.
