go the subie.
for the amount of off roading youre looking at, its bot worth giving up the car feeling.
just keep up those upper engine cleans.
I am almost there with you. However people we go camping with have a Prado, a Vitara and a Navara. The Suzuki stands a better chance of being able to go wherever they go, which would be nice.
Will have to go drive both and see where that leaves us.
24 hour test drive through the mountains?
24 hour trial as a grocery getter would be better! Don't need it to be a good mountain runner, just needs to be a solid car like the 3 is with added 4x4
Mr Scott, Mr Tony, Mr Bunta, Mr Luke.... *sup nod*
Morning
Morning
What you say is true. Those 24 hour test drives must be awesome!
So, I've done some research into sprint days. Categories are as follows: 4 cyl, 6 cyl, 8 cyl and AWD. Turbo/super charged vehicles move up on category therefore Mike and Nick will be in the same category for sprints.
So will Martin
And Matt
And Zeke
And everyone else who wants to rip apart the Abomination
Nice. So you're going for a brand new one?
With the Forrester no, the new model has a range of limitations that put it out of the running, So for Forester we would be looking at a 2012 to 2010, Vitara will likely be new, especially if I lease, Remserv was offering very good deals on Vitara for QLD government employees as in 4k below retail good
So will Martin
And Matt
And Zeke
If i run RWD can I beat up on the A-Bomb too?
With the new vitara, what are servicing costs like in order to maintain warranty?
With RWD, I believe so. If you can demonstrate that the car will only be running in RWD mode without the ability to switch on track, I don't see it being an issue.
Ants should join in as well. I would love to see a stock standard NA R33 beat his ass around QR. Although, I'm pretty sure that Martin will run the Pinny and flog him.
So will Martin
And Matt
And Zeke
Nick is too much of a skirt to enter so we won't be able to :(
If i lease, the cost of servicing is built in. but its around 300 bucks per 10,000km
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
