I know but wouldn't it be nice if the world was Cadbury? It just doesn't look good when people bitch and moan about shot that they don't plan on attending and ruining it for other prospective attendees.
such a shame.
and unfortunately theres not really much you can do about it.
Sold cheap to friend, he loves parting stuff out so he can make some good coin from it
Morning all
Night people. Pretty disappoint with AGM.
What the???? So the AGM has already taken place? I had it in my diary for Tuesday the 27 August
The problem with everything ever is that there will be people who are not happy. You can't make everyone happy and as long as people are attending events then that is all that matters.
People despite their sometimes innate ability to display a mental deficit are entirely capable of forming opinions on their own and while some people will influence a small number of people the Majority will arrive at a conclusion based on the information on hand.
the smart version of my original, cant do anything, post.
So I had an interesting trip to work today, got caught behind a tradie protest, then they blocked our driveway for 2 hours, good times.
If you want more money finish high school you fecking plebs. :P
    • Did and sync timing with light
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
