I need the wings to keep my fat fingers off of the desk, they create drag while playing shooters, They are optional too.
It does 6400 DPI now and I barely use above 4000
Hero derp computa derp mouse lad derp CPU herp
Mine at work goes up to 5700. It has the ability to shift DPI at the click of a button on the mouse so it works well when head hunting and stuff.
Can have five settings at once. Currently I have: 350, 800, 1600 (most commonly used), 3200 (occassionally used), 4500 (for shiggles when anyone wants to use my laptop :P)
I got the Logitech G9x. Works well. Nice feel, balance and weight. Looks pretty. Has wing for thumb but not pinky which I like as well. :) $40 - not a bad buy. Work also gave me $20 for it so total cost to me was only $20 :)
yup 3000k ish is good. any more is weird. good buy. Logitech ftw!
shoosh Cleatus, and go back to doing skids in your tractor powered Boat
Hey I dun found a tooth, now I looks like Britten spears
How you doin'?
ok mate. I've been a bit stressed lately tbh. Got lots of things happening in my life right now and trying to manage it to the best of my ability............life as we know it.
Life can be fun like that. Be grateful for all that you have and things will become easier. :)
    • Did and sync timing with light
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
