Beer and games for me tonight. that's all I want..............................ohhhh and to win the lotto would also be good :yes:
I am playing Battlefield 3... Building your machine has me gaming again.
have been eyeballing these on ebay.
bit remember, I need a puter that works first.
Good Value so far, I like the wireless and 2 battery's. so comfortable too as it is all adjustable
have also been looking at the thermaltake mouse.
Boo Hiss, Horrible Items. Razer make good mice if your not in the market for a RAT.
