Glorious day today for my Birthday
Happy Birthday Ants
Speaking of research my last project was links. I got it in the car. Found the set up file. Went to configure it and see if it would fire up....flat battery :(
That sucks wang.
What do u plan to use the car for?
Few options out there, but the only real ones I'd look at for high output handling capabilities vs dollars invested are C4, Th400 and power glides.
I've heard some guys in the states doing fantastic things with the re4r03a (300zx auto) but its pricey, I believe tony rigollis mob builds them over here same deal with the old school 3 speed jatco boxes which the name illudes me of but I've seen people pull decent numbers from them as we'll.
T350 boxes are good and don't suck as much power from the drivetrain as the beefier T400 boxes.
Timmeh! When will we see you in a skyline again!?
This week! Fingers crossed.
If my vast knowledge of Mr Tim is correct he owns an r34 is in it as we speak
Your vast knowledge is correct. Well, I own it but I haven't got it yet - just waiting on compliance to finish up before taking it for a spin....
Nice one! Will be keen to have a look.
A spin up to see Chris right? Making sure that nobody else takes it for a spin ;)
Getting excited? In other news, WASSSSUUUPPP TIIMMMEEEHHH???
Hopfully it is all good. I dunno about that but if drag is your thing they have the runs on the board!
Happy Birthday big guy!
Thanks buddy.
Happy birthday mr ants :)
Cheers Nicky.
#@SCR48
Get a power glide, get a transbrake, do this >
^ this as well
Happy Birthday
Thanks Clint.
Happy Birthday Ants
That sucks wang.
thank you kindly
Happy Bursting out from your mum's vajajay day Mr. Ants!
Well put and thank you sir :laugh:
In reading about the G4 I was saddened to learn that it had to run wasted spark, Nek minnit, read a little further and Microtech makes a ignitor with 6 ignition drivers that you can hook up to the link for only 195 bucks, sweet!
Everything seems compatible with them
That photo makes it look like you got sick of it and took the Ant Eater to the wreckers :( lol
twas kinda of tongue in cheek :P
Have to say that EFI performance is really isolated due to those industrial / scrap yards.
When I was speaking to Sean he was fixing his dyno cause its got some issues.
g4 are good ECUs and pretty sure it will be able to adapt to what you require Bunts.
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
