Why bother? My car is faster than yours in a straight line, faster round corners, better at stopping, better looking, and doesn't sound like a wookie's wet fart. I need to suck at launches to give you a chance to be better at something :PThere usually are bits where you need to reverse.
Better looking, nope, mine doesn't look like a door stop.
Faster in a straight line, aslong as we do roll ons from 100
And I'd put money on a majority of people saying mine sounds better as it dosent whistle and drone it's way around the place
Nup. Prefer the look of the wedge. For starters, it's not orange.
I'd put my money on McFly still flogging from a 100km/h start.
Around here, the majority would say that his sings a sweeter tune.
I think this needs a vote. Tony get on it #@t5iv
My ET was faster, was only my shitty launch that let you win by 8 hundredths
Mine doesn't drone. The only people who would like how yours sounds would be falcodore bogans. But since 'the majority of people' in 'straya are falcodore bogans, you may be right there :P
But that's your secret Martin... You are a dick ;)
That's no secret...
List of events that we went through in a fair amount of detail at the AGM last night.
I see, Is the motorkhana going to be at QR again?
Sh*t, I paid yesterday, didn't I email you?
I dont think so, that is good, we now have 4 paid, its harder to get these cricket clowns to pay for stuff than SAU
I think this needs a vote. Tony get on it #@t5ivMy ET was faster, was only my shitty launch that let you win by 8 hundredthsMine doesn't drone. The only people who would like how yours sounds would be falcodore bogans. But since 'the majority of people' in 'straya are falcodore bogans, you may be right there :P
That's no secret...
How many things do you want a vote on?! Geez!
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
