When he clears his back log I suppose. I am guessing leading up to powercruise this weekend was a hectic time for them. I am not really in a rush any more, Anna has started working so when those funds trickle through I will go get it done.
I R Jelly
lol re backlog........guess that includes me too. Yep, 100 bucks I dont get my car this week......................again.
Just spoke with Richard, That thing is going to be mental man, Sweet they look meaty
My car? Hopefully. Richard is such a good bloke could talk to him for hours.. I was just posting in the spotted thread. they have a 34 GTR at the moment getting some HP upgrades too. to skylines both getting precision turbo upgrades.
hahaha, Will be a thrid down there in a week or so. How long are you expecting until you get it back. Are you going E85 straight off the bat with this one?
Yeah ill be going e85, in my opinion is not worth tuning on anything these days. specially if the car isnt driven as a daily. I would highly recommend giving your's a go on it Clint. It will feel like a totally different car.
In regards to time frame. I havent really set one on it and am happy for it to take as long as it take to get it right. Id like it to be ready for the downshift QR day on the 28th of this month but if it isnt im not overly fussed. Next big event i want to take it to will be powerplay or a SAU event
I'll do mine the day E85 is readdily available on the North side, that is the only thing holding me back. it is still (for now) a daily.
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
