No of course not...I don't tell anyone what I've done to my car :P
Yes I am and yes you can feel it...and the clutch too if ya want :O
i dont spose u'd drop the brand of it then? or the brand u'd get if u were going to get one :(
Geebus I hope you are talking about the clutch......... :cheers:
oh dear dave's got his mind in the gutter again :D
morning karen :cheers:
looks good too john, call me when you want some professional photos and i can hook you up, that applies to everyone also.
my photos are close enough to professionalism
just got to get around to opening them up now in Adobe Photoshop and editing them with more colour and lighting in certain areas.
REAL PROFESSIONAL PHOTOS I DONE -
http://www.skylinesaustralia.com/forums/in...t&p=2780330
those have been touched up in photoshop.
What do you mean by that?? If I was going to replace it you mean?
what brand of clutch is your :cheers:
P.S dave ur a big girl, u whinge more than a woman during...no i wont say that :D*runs and hides*
we discovered yesterday that shanes not only ghey
but also likes 14yr old girls at servos....
had to go let off some steam in the toilet while we were waitin for ian to finish his roll.
lmfao!!!
dude she was 16, get it right! :cheers:
http://www.news.com.au/story/0,23599,21025660-2,00.html
P-PLATE drivers will be given no second chances before having their licence cancelled under the toughest driving conditions yet being considered by the New South Wales Government.
bahaha sux to be them :cheers:
I dunno what Ian has
yeah ian's got a nismo twin plate
I think this is a good idea to some extent, but in saying that, the Government needs to provide a place where young drivers CAN drive fast (I know you can already do this at Eastern Creek, but I'm saying this more in relation to the Qld Government, because if NSW gets this proposal passed you can bet Qld will be very quick in following suit).
Guest
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • I guess one thing that might be wrong is the manifold pressure.  It is a constant -5.9 and never moves even under 100% throttle and load.  I would expect it to atleast go to 0 correct?  It's doing this with the OEM MAP as well as the ECU vacuum sensor. When trying to tune the base map under load the crosshairs only climb vertically with RPM, but always in the -5.9 column.
    • AHHHH gotchaa, I'll do that once I am home again. I tried doing the harness with the multimeter but it seems the car needed a jump, there was no power when it was in the "ON" position. Not sure if I should use car battery jump starter or if its because the stuff that has been disconnect the car just does send power.
