had to get the ball rolling at some stage
hehehe
only got my car and noy's car left to shoot.
which reminds me i should organise a time with him this wk to do his car
got to wash mine first before i even go anywhere near it with a camera
washing is the pits :rant:
think people would be satisified paying around $28/$29 for a calendar this year?
Should be..it is more detailed than last years
specially in the sun at this time of year
Yep
PS 5 pages in a row Pwned by me
I have this choice....
run a batch of 50 calendars off, each calendar will be $28 or $29 each.
run a batch of 100 calendars off, each calendar will be $25 or $26 each.
since I have to fork up the full amount for the calendars, running 100 of them may see a few of them left in a box not being purchased which i then end up being out of pocket.
can only run these off in batch's of 50.
so, there is the choice of
run the 100 and hope they all get sold
or
run 50 and tell anyone who was to late in ordering them 'tuff luck'
Ask mud how many were sold last year?
Ian......your clutch is buggered, just recently gone through this myself so I know the evil symptoms lol
*waits for the call of shameless plug*
:P
The Perfect Day According to HER:
8:45 Wake up to hugs and kisses
9:00 5 lbs lighter on the scales
9:30 Light breakfast
11:00 Sunbathe
12:30 Lunch with best friend at outdoor cafe
13:45 Shopping
14:30 Bump into boyfriend/husband's ex - notice she's put on 2 stone
15:00 Facial, massage, nap
19:30 Candlelight dinner for two and dancing
22:00 Make love
23:30 Pillow talk in his big strong arms
The Perfect Day According to HIM:
10:00 Wake up
10:02 Oral sex
10:10 Big breakfast
11:30 Drive up coast in Ferrari with gorgeous babe with big hooters
14:15 Enormous lunch
15:15 Oral sex
15:25 Play sports with the guys
16:30 Drink much beer with the guys
18:30 Meet Claudia Schiffer
18:40 Oral sex
18:50 Huge dinner, more beer
23:00 Full on, get down, gorilla sex
23:15 Sleep
i'm not sick but i'm not wellllllllll
and i'm so hiiiiiiiiiiigh
cause i'm in hell!
mike is back!!
and pissed off!!!! stupid pubmole went home sick! now i gotta work till 7! that fat mole! she's apparently pregnant. who in their right mind would do her! you'd have to be blind, no sense of smell, no feeling in ANY part of your body and have no hearing :P
this sucks. i wanna quit :(
cause i'm in hell!
mike is back!!
do it
11:00 Sunbathe
13:45 Shopping
22:00 Make love
10:00 Wake up
10:02 Oral sex
10:10 Big breakfast
15:15 Oral sex
18:40 Oral sex
23:15 Sleep
besides the ferrari and claudia schiffer, that sounds just like high school to me, no kidding :( my ex from back then actually expected those things of me each week :P i still didnt do them :( being male ftw!
do it
no job to go to yet. should prob have a look around.
something giving you the shits mike?
ignorant fat moles that work for me. this is her 3rd sick day in three weeks. i'm just gonna fire her soon, giving me the shits.
Guest
    • Did this end up working? Did you take some pictures?
    • And finally, the front lower mount. It was doubly weird. Firstly, the lower mount is held in with a bracket that has 3 bolts (it also acts as the steering lock stop), and then a nut on the shock lower mount itself. So, remove the 3x 14mm head bolts , then the 17mm nut that holds the shock in. From there, you can't actually remove the shock from the lower mount bolt (took me a while to work that out....) Sadly I don't have a pic of the other side, but the swaybar mounts to the same bolt that holds the shock in. You need to push that swaybar mount/bolt back so the shock can be pulled out past the lower control arm.  In this pic you can see the bolt partly pushed back, but it had to go further than that to release the shock. Once the shock is out, putting the new one in is "reverse of disassembly". Put the top of the shock through at least one hole and put a nut on loosely to hold it in place. Put the lower end in place and push the swaybar mount / shock bolt back in place, then loosely attach the other 2 top nuts. Bolt the bracket back in place with the 14mm head bolts and finally put the nut onto the lower bolt. Done....you have new suspension on your v37!
    • And now to the front.  No pics of the 3 nuts holding the front struts on, they are easy to spot. Undo 2 and leave the closest one on loosely. Underneath we have to deal with the wiring again, but this time its worse because the plug is behind the guard liner. You'll have to decide how much of the guard liner to remove, I undid the lower liner's top, inside and lower clips, but didn't pull it full off the guard. Same issue undoing the plug as at the rear, you need to firmly push the release clip from below while equally firmly gripping the plug body and pulling it out of  the socket. I used my fancy electrical disconnect pliers to get in there There is also one clip for the wiring, unlike at the rear I could not get behind it so just had to lever it up and out.....not in great condition to re-use in future.
    • Onto the rear lower shock mount. It's worth starting with a decent degrease to remove 10+ years of road grime, and perhaps also spray a penetrating oil on the shock lower nut. Don't forget to include the shock wiring and plug in the clean.... Deal with the wiring first; you need to release 2 clips where the wiring goes into the bracket (use long nose pliers behind the bracket to compress the clip so you can reuse it), and the rubber mount slides out, then release the plug.  I found it very hard to unplug, from underneath you can compress the tab with a screwdriver or similar, and gently but firmly pull the plug out of the socket (regular pliers may help but don't put too much pressure on the plastic. The lower mount is straightforward, 17mm nut and you can pull the shock out. As I wasn't putting a standard shock back in, I gave the car side wiring socket a generous gob of dialectric grease to keep crap out in the future. Putting the new shock in is straightforward, feed it into at least 1 of the bolt holes at the top and reach around to put a nut on it to hold it up. Then put on the other 2 top nuts loosely and put the shock onto the lower mounting bolt (you may need to lift the hub a little if the new shock is shorter). Tighten the lower nut and 3 upper nuts and you are done. In my case the BC Racing shocks came assembled for the fronts, but the rears needed to re-use the factory strut tops. For that you need spring compressors to take the pressure off the top nut (they are compressed enough when the spring can move between the top and bottom spring seats. Then a 17mm ring spanner to undo the nut while using an 8mm open spanner to stop the shaft turning (or, if you are really lucky you might get it off with a rattle gun).
    • You will now be able to lift the parcel shelf trim enough to get to the shock cover bolts; if you need to full remove the parcel shelf trim for some reason you also remove the escutcheons around the rear seat release and you will have to unplug the high stop light wiring from the boot. Next up is removal of the bracket; 6 nuts and a bolt Good news, you've finally got to the strut top! Remove the dust cover and the 3 shock mount nuts (perhaps leave 1 on lightly for now....) Same on the other side, but easier now you've done it all before
