last time i used public transport i was ushered on stood on the bus for 30mins... fat ladies rubbed ther gross bodies on me.. and i smelt like a mexican farmer afterwards..
so if they want me to catch a bus.. make it anything but a migration zoo.
Well you can stop using transport and make love more often with lesbo? :laugh:
it'll save greenhouse gasses, as all your making is some steam :happy::P!!!
cant belive i just said that hehe!
My list....that doesn't even come close to everything....
-APEXi - Power FC & Hand Controller Mazda - RX7 - Series 1-3 91/12-95/11 414-AZ004 BACK ORDER 3 WEEK WAIT AU $ 862.40
-APEXi - Power FC - Boost Controller Kit To Suit PowerFC 415-A008
AU $ 341.47
-Billion - Super Solid Coolant Line Mazda RX-7 FD3S BWL-12
AU $ 153.20
-Blitz - Dual Turbo Timer - DCIV Blitz - DTT - DCIV 4369 AU $ 170.17
-Cusco - Brake Cylinder Stopper Mazda - RX-7 FD3S 91/11-422 561 A
AU $ 64.10
-Cusco - LSD - Type MZ Mazda - RX7 FD3S - 2 Way LSD 165 K2
AU $ 877.90
-Cusco - Oil Catch Tank Universal - 15mm 00B 009 HB AU $ 96.84
-Cusco - Strut Brace - Type ALC OS Type ALC OS - FD3S - Front422 535 A
AU $ 177.74
-Do Luck - Rear Cross Bar Mazda RX7 FD3S AU $ 347.07
-Endless - CC-R Brake Pads Mazda RX 7 FD3S Front & Rear Set EP282
AU $ 461.64
-Exedy - Hyper Compe R Twin Plate Clutch Mazda RX7 FD3S 13B-REW (Twin Plate) ZM022SBL AU $ 1,651.48
-Exedy - Light flywheel Mazda RX7 FC3S 13BT, FD3S 13BT-REW (Needs Standard Counter Weight)ZF01 AU $ 406.40
-HKS - Fuel Injectors HKS 680cc Top Fed Injector 1402-RZ002
AU $ 123.15
-HKS - Hipermax II - Full kit Mazda RX7 FD3S 13B REW Front 6K Rear 5K
1760-SZ001 AU $ 1,538.15
-HKS - Twin Power Mazda RX-7 FD3S Twin Power Harness Z-1 (FD3S)
4399-SZ001 Z-1 AU $ 40.30
-Project Mu - SCR Mazda RX7 FD3S SCR Front Rotors X 2 (16 inch) SCRZ022 AU $ 339.57
-Sard - Fuel Regulator - Adapter to Suit Nissan ,Subaru & Mazda 69014
AU $ 21.27
-Trust - Greddy - Aluminium Radiator Mazda E-FD3S 13B-REW 92.11~ H631.8×W315×D48 12043700 AU $ 738.92
-Trust - Greddy - Intercooler SPEC-V Mazda RX-7 FD3S 13B-REW 1/12-02/8 SPEC-V Type 24C H284/L600/W76mm, 2 Layer (Radiator front)(Greddy Compression Tube, Airinx Set (MZ-S001B) Needed, Change the battery(38B20R), Nomal turbine) AU $ 1,062.40
-Trust - Greddy - Oil Filler Cap Mazda - Type 4 - Chrome Silver - M35 P4.0 - 13B, B3, B6, BP and JE 13941024 AU $ 74.31
-Trust - Greddy - Oil Filter - Moval Kit To Suit Mazda RX7 FD3S 13B�?REW
12043003 AU $ 151.14
-Trust - Greddy - Power Extreme - Ti-R Mazda - RX7 - FD3S - 91/11-02/8 - 90mm Pipe - 115mm Tail 10141054 AU $ 1,126.81
-Trust - Greddy - Turbo Kit - Mazda RX7 - External Wastegate Mazda RX7 E- FD3S 13B-REW 91/12 - 98/11 TD-06SH, 25G-16.0cm2 (EX manifold, WG Type R08, AIRNX,AY-M)AIR PUMP CANNOT BE ATTACHED 11540031
AU $ 4,259.61
Order Total
AU $ 15,086.06
Guest
    • Hey everyone. Is there a way I can get the original window sticker (maroney label) for my 1995 R33 GTST? I doubt I’ll be able to ever get it but it’s worth a shot to ask
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
