Heres the go Milky.
A. you dont own a skyline
B. you arent a member
C. you are a cockhead
Three strikes and you're out, Onyabike tosspot :):laugh:
bahahahahaha here's the go for you oldtimer:
A. You're old
B. You're a n00b
C. You think you're cool
D. You're a wanker
funny thing about you Oldtimer is, you think paying me out is going to get you rep points, but problem is i've been here a lot longer than you and you've been here 2 minutes and already think you make the rules (1: overall, hardly anyone is a "member" 2:heaps of people don't own skylines on here and 3:Your opinion doesn't count for anything) I've seen you mid life crisis type go through here quite a bit..given your case is a little sader but none the less....like I said go back to playing with your car, putting on the wrong offset wheels and talking about your awesome alarm you got installed by autobarn.
Mightnt be for you but it would suck for me. i doubt that any road rules we tested under are even in existence today. :)
dude back in your day you could get other people go for licence for you and i think the test was to drive the coppa down to the nearest takeaway and buy him lunch.... true story....
Mightnt be for you but it would suck for me. i doubt that any road rules we tested under are even in existence today. :laugh:
This is true, wouldn't be worth it. Nothing has changed enough for me since I 1st got my license to make it hard, where as in 1928 you'd have what like 2 rules? :)
Josh's great trickery scam sounds good on paper, but we're forgetting Vic license = I must drive cars that meet their power to weight.
P.s f**k using a p plate haha
Morning milky. had your heinz 3 veg mix yet. :)
ahahah LOL :laugh:
Feeling tough this morning??....f*ck off and die already...i'm sick of wasting my time arguing with you...you're always wrong, your arguments are crap and you aren't worth my time.
ahahah LOL :)
Heres the go Milky.
Three strikes and you're out, Onyabike tosspot :O:D
ahahah LOL :laugh: + :D
NOELS WINNING MATT... :D
anyway morning sau.. did u all poop alot since last night..? im eating beef meatballs and fried rice :D
if only you knew how true that was bloke. However, after i left the outback and came to Bris I managed to actually lose my license a time or 2 and had to sit real tests. That sucked.
u have to stick up for noel or u'll be walking half the time!
Niz and ole grey one have reached an understanding. He understands that I am a cantankerous old c#$#$
And I understand that he wants to be just like me when he gets old. :):):)
My mum's dad was an inspector in NSW..and what you're saying is right, except that in her case the licensing officer asked "can she drive mate" he said "yeah shes a good driver" She got her license then and there...hahaha
Guest
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
