W00t, omg like zomg, we can have mini sales meetings and stuff :cheers:
Yeh you'll have to teach me good techniques hehe
Never mind Anna Banana
new question!!!
You saying andy looks like a 50 year old balding man?
appears old marki has left us :laugh: He hasnt been on msn either
i told ya he was a softcock, right from the start :happy:
but saying that, its amazing how lee's still here, seeing as he's just as soft :cheers:
appears old marki has left us :( He hasnt been on msn either
Neither have you!! he he he i've been hiding :)
:happy: yeah? that dude and Andy just look similar....
i told ya he was a softcock, right from the start :laugh:
300px-Trawling_Drawing.jpg Trawling for a ass whooping i see Shane....
Oh, and if anyone knows of someone wanting a place to rent, we now actually have a spare room - our housemate is moving back to Darwin.
whats rent? the details? split bills?
I'm on and off all day
Lies All Lies!!!
i know where mark is ...... but i will keep my silly coments to my self as your all prolly sick of the shit between us...... sumthing to do with dodgy vehicle and fridgid gf :cheers:
What are you selling?
Phones. LOL i've already picked out my new one :laugh: I love getting new phones
ill teach you some tricks anna, i learnt alot from 3 years selling dodgy used cars
siiiiiiik! SAu support group FTW :)
Interesting... Oh I have a letter here for you Lee. What? There's something inside? Oh I know, it's ANTHRAX, Yarrrrrr :cheers:
Rent is $80 a week, large bedroom, built-ins with mirrors, main bathroom all to themselves, split bills as required (electricity / home phone (if they use it). I'm advertising on the uni websites, we'd love another japanese exchange student.
Neither have you!! he he he i've been hiding :laugh:
:cheers: yeah? that dude and Andy just look similar....
i dont need to trawl, as i have a can right here. want me to open it? :happy:
Guest
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • I guess one thing that might be wrong is the manifold pressure.  It is a constant -5.9 and never moves even under 100% throttle and load.  I would expect it to atleast go to 0 correct?  It's doing this with the OEM MAP as well as the ECU vacuum sensor. When trying to tune the base map under load the crosshairs only climb vertically with RPM, but always in the -5.9 column.
    • AHHHH gotchaa, I'll do that once I am home again. I tried doing the harness with the multimeter but it seems the car needed a jump, there was no power when it was in the "ON" position. Not sure if I should use car battery jump starter or if its because the stuff that has been disconnect the car just does send power.
    • As far as I can tell I have everything properly set in the Haltech software for engine size, injector data, all sensors seem to be reporting proper numbers.  If I change any injector details it doesnt run right.    Changing the base map is having the biggest change in response, im not sure how people are saying it doesnt really matter.  I'm guessing under normal conditions the ECU is able to self adjust and keep everything smooth.   Right now my best performance is happening by lowering the base map just enough to where the ECU us doing short term cut of about 45% to reach the target Lambda of 14.7.  That way when I start putting load on it still has high enough fuel map to not be so lean.  After 2500 rpm I raised the base map to what would be really rich at no load, but still helps with the lean spots on load.  I figure I don't have much reason to be above 2500rpm with no load.  When watching other videos it seems their target is reached much faster than mine.  Mine takes forever to adjust and reach the target. My next few days will be spent making sure timing is good, it was running fine before doing the ECU and DBW swap, but want to verify.  I'll also probably swap in the new injectors I bought as well as a walbro 255 pump.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
