if i was going something non plastic.. it wouldnt be a matchbox car of a toyota.. it would be an olds mobile..
now THAT car is fat... put a 451 chevvy gine in it.. with a Supercharger... and the difference is.. that bad boy could handle it..
makes me wanna go and get a burger and fries from a chick on roller blades..
There is no debate, I like older cars more so then new ones.
NEXT
Almost there dem 55/57 chevy ftw
yah.. its a 57 noel :D and its fkn fat... if i didnt go the kick ass jap cars.. i would of done one of these up..
however my fuel bill would of been even larger lol
I came within a mick hair of owning a 55. Guy wanted to swap for my monaro. I often wonder what if.
blue oval = vomit. bowties own it.
sadly.. i love the style of it.... and id be happy with that thing sitting in my garage as a project..
ever though about doing up a 20-30's car into a hotrod supa car noel?
Lee, here is the one in QLD thats been built for drift events.
Before people jump on the weight bandwagon a 1uzfe is 177kg with no gearbox, and an sr20 is something like 130kg. This can be fixed with correct suspension set ups.
GAH!!! you should of traded... the monaro aint going nowhere.. you can still pick up those bucket of craps for under 10k
then again.. you may not of become a skyliner.. i know that if i got my hands on one of these i would of kept down the classic track
NO..Flat NO!. Hot rods are farking ugly imo. Rarely have I seen one that I would call hot looking. Lots of work in them and some good quality stuff too, but at the end of the day its still a chopped up ugly arese bucket.
I much prefer full restos in that vintage rather than rodded shit.
Na? :D
If i still owned that monaro today I could write my own ticket bro. HT gts 350 bathurst edition. have you seen the krazy money they are going for?
Na? :D
Yes. cat back exhaust, simple induction on an auto 130 - 140rwkw. With a manual 150rwkw+.
That s13 has a tuned ecu, haltech i think, the stock 1uzfe ecu is a major let down and a joke. the haltech will push that car up around 200rwkw+ untill he gets some extractors.
We share the same opinion on something. What type of cars, or pure just old muscle cars?
quite a few of the earlier caddys. chevs and even some fords look fantastic in full resto.
Muscle cars do own it for me tho. 68 comaro, some of the vettes. couple of stangs. Never a dodge fan despite their all conquering hemi. The cars were farkin ugly cheap built shit boxes.
You sure could, dad had historic cars, lots of ex racers at phillip island ect, not so much ozzie/american muscel cars. To re right time over agian.
Among other things, oldest MG in Australia, second oldest in the world.
Not everyones thing, however gotta give it respect for what it is and its history.
Guest
    • And now to the front.  No pics of the 3 nuts holding the front struts on, they are easy to spot. Undo 2 and leave the closest one on loosely. Underneath we have to deal with the wiring again, but this time its worse because the plug is behind the guard liner. You'll have to decide how much of the guard liner to remove, I undid the lower liner's top, inside and lower clips, but didn't pull it full off the guard. Same issue undoing the plug as at the rear, you need to firmly push the release clip from below while equally firmly gripping the plug body and pulling it out of  the socket. I used my fancy electrical disconnect pliers to get in there There is also one clip for the wiring, unlike at the rear I could not get behind it so just had to lever it up and out.....not in great condition to re-use in future.
    • Onto the rear lower shock mount. It's worth starting with a decent degrease to remove 10+ years of road grime, and perhaps also spray a penetrating oil on the shock lower nut. Don't forget to include the shock wiring and plug in the clean.... Deal with the wiring first; you need to release 2 clips where the wiring goes into the bracket (use long nose pliers behind the bracket to compress the clip so you can reuse it), and the rubber mount slides out, then release the plug.  I found it very hard to unplug, from underneath you can compress the tab with a screwdriver or similar, and gently but firmly pull the plug out of the socket (regular pliers may help but don't put too much pressure on the plastic. The lower mount is straightforward, 17mm nut and you can pull the shock out. As I wasn't putting a standard shock back in, I gave the car side wiring socket a generous gob of dialectric grease to keep crap out in the future. Putting the new shock in is straightforward, feed it into at least 1 of the bolt holes at the top and reach around to put a nut on it to hold it up. Then put on the other 2 top nuts loosely and put the shock onto the lower mounting bolt (you may need to lift the hub a little if the new shock is shorter). Tighten the lower nut and 3 upper nuts and you are done.
    • You will now be able to lift the parcel shelf trim enough to get to the shock cover bolts; if you need to full remove the parcel shelf trim for some reason you also remove the escutcheons around the rear seat release and you will have to unplug the high stop light wiring from the boot. Next up is removal of the bracket; 6 nuts and a bolt Good news, you've finally got to the strut top! Remove the dust cover and the 3 shock mount nuts (perhaps leave 1 on lightly for now....) Same on the other side, but easier now you've done it all before
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
