tell me this if this deal sounds alrite...
swap my R34 N1's for a set of HKS GT-RS's + $500 his way. both sets are pretty much new
Are the hks a better turbo than the N1's. If they are then why does he want to swap.
If you dont take that I will know you are stalling on getting your car finnished!
They are the turbos you want (really one of the few low mounts that will hit your target) for minimal outlay and you get rid of a set of turbos you dont want.
Get them checked for play and you are set!
As posted in forsale section on qld but usually this gets more looks, I need a front drivers side window motor for my r33 series 1 skyline, mine just shit itself today :happy: if you guys can help me out that would be great or point me to a skyline wreckers in se brisbane to locate on that would be great cheers.
adam
bigger
but the GT-RS are too laggy on his 2.6l gtr :)
they'll be perfect for my 3ltr :(
I'd be sticking with the N1's Shane ;)
too small karen :(
home time!
shane.. ask boonta! he knows everything.
he's an asshat though :happy:
zomg thanks for the reply asshat :P
but then i'd have HKS parts on my car :P
they are off the bayside blue 34 gtr that's out at the track a fair bit, baboo from here owns it, that's where i got the std r34 turbo's from and told him when he wants to get rid of the rs's let me know, fancy that lol
i'll get them checked and hopefully i'll have turbo's sorted :huh:
adam
ring the guys at cresta.
Cresta Australia Pty Ltd
Sd 2/ 9 Smith St Capalaba 4157 (07) 3245 1555
howdy donkey man :P
got any good news? or is it all bad? :happy:
the bad news is that your mum gave me a std
the good news is that there is medication for it
jokes
nah its getting there man
jokes
dammit my plan failed! :happy:
what was found when it got pulled down?
Guest
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
