I love detailed build threads in general, Ant's has an awesome one, Mat's just makes me jealous.34 Shell shouldn't be too hard to find I would Imagine.
yea me too. I love detailed build threads it's like lookin at a pawn almost :P
If it still isn't fixed you can come up and drive mine, It's no GTR but she goes.
thanks mate. Means a lot. Hopefully it will be all sorted out this week and maybe I could come up with the ant-eater instead :)
Also, I know your beast goes ;)
:yes:
Looking forward to it. No excuse not to come to LAN events then.
I'm forever throwing my keys at my friends offering them a go behind the wheel. But they are all too scared to drive it :-(
I just want to ride shotgun occasionally to truly appreciate the power my car makes. Always feels faster when your not in control!!!
You never throw me the keys, I'll give it a crack.
So true, after I got my gear box done i got my mate to take me for a drive in the passenger seat, first time he punched first I literally went "holly f**k!" Lol, not that it's anything crazy but it does feel faster in the passenger seat
Yeah the missus never puts her foot down when she drives it.
Mountain may be involved.
Mine refuses to dive it. Doesnt even like going in it due to the coilovers lol
I love the feeling. Makes you love the car more i reckon.
Have we even met? lol. Im sure once we do your welcome to have a chop
My girlfriend is also to scared to put her foot down when she drives mine and it's not even powerfull...only makes 180rwkw.
Mountain WILL be involved.
Yep, at QR happy laps. Apparently I have a reputation for being a bit quick on mountains or something, I just think Tony overstates it. Also people tend to come off the road or get fined on mountain runs with me.
Guest
    • You won't need to do that if your happy to learn to tune it yourself. You 100% do not need to do that. It is not part of the learning process. It's not like driving on track and 'finding the limit by stepping over the limit'. You should not ever accidently blow up an engine and you should have setup the ECU's engine protection to save you from yourself while you are learning anyway. Plenty of us have tuned their own cars, myself included. We still come here for advice/guidance/new ideas etc.  What have you been doing so far to learn how to tune?
    • Put the ECU's MAP line in your mouth. Blow as hard as you can. You should be able to see about 10 kPa, maybe 15 kPa positive pressure. Suck on it. You should be able to generate a decent vacuum to about the same level also. Note that this is only ~2 psi either way. If the MAP is reading -5 psi all the time, ignition on, engine running or not, driving around or not, then it is severely f**ked. Also, you SHOULD NOT BE DRIVING IT WITHOUT A LOAD REFERENCE. You will break the engine. Badly.
    • Could be correct. Meter might be that far out. Compare against a known 5 ohm 1% resistor.
    • @Murray_Calavera  If I were an expert I wouldn't be in here looking for assistance.  I am extremely computer literate, have above average understanding on how things should be working and how they should tie together.  If I need to go to a professional tuner so be it, but I'd much rather learn and do things myself even if it means looking for some guidance along the way and blowing up a few engines. @GTSBoy  I was hoping it would be as simple as a large vacuum leak somewhere but I'm unable to find anything, all lines seem to be well capped or going where they need to be, and when removed there is vacuum felt on the tube.  It would be odd for the Haltech built in MAP to be faulty, the GTT tune I imported had it enabled from the start, I incorrectly assumed it was reading a signal from the stock MAP, but that doesn't exist.  After running a vacuum hose to the ECU the signal doesn't change more than 0.2 in either direction.   I'll probably upload a video of my settings tomorrow, as it stands I'm able to daily drive, but getting stuttering when giving it gas from idle, so pulling away from lights is a slow process of revving it up and feathering the clutch until its moving, then it will accelerate fine.  It sounds like I need to get to the bottom of the manifold pressure issue, but the ignition timing section is most intimidating to me and will probably let a pro do that part.  Tomorrow I'll try a different vacuum line to T off of, with any luck I selected one that was already bypassed during the DBW swap.  (edit: I went out and did it right now, the line I had chosen did appear to have no vacuum on it, it used to go to the front of the intake, I've now completely blocked that one off at the bracket that holds several vacuum lines by the firewall.  I T'd into the vacuum line that goes from that bracket to the vacuum pump at the front of the car, but no change in the MAP readings).  Using the new vacuum line that has obvious vacuum on the hose, im still only getting readings between -6.0 and -5.2.  I'm wondering why the ECU was detecting -5.3 when nothing was connected to the MAP nipple and ECU MAP selected as the source. @feartherb26  I do have +T in the works but wanted to wait until Spring to start with that swap since this is my good winter AWD vehicle.  When removing the butterfly, did it leave a bunch of holes in the manifold that you needed to plug?  I thought about removing it but assumed it would be a mess.   I notice no difference when capping the vacuum line to it or letting it do its thing.  This whole thing has convinced me to just get a forward facing manifold when the time comes though.
    • Update: tested my spark plugs that are supposed to be 5ohms with a 10% deviation and one gave me a 0 ohms reading and the rest were 3.9ohm<, so one bad and the others on their way out.
