i dont do wat you do to 14yr olds. get it right.
or even better yet, i dont meet girls and offer to fix there car and then in exchange ask for sex.
thats right, you deni all that yet, mods on cruisingbrisbane have pm's and logs of it all.
hence why your banned not once, not twice by 3 TIMES!!!! under different nicknames for the abuse, threats, harassement, etc.
btw, if i was you eddy, i wouldnt go out cruising all that often. a few of the guys on cruisingbrisbane would like to meet up with you. one i wouldnt want to get in the way of, thats for sure!
hmm quite a story that. MEL504 owes me $$ for the gearbox and the labour. no sex was exchanged for the work i did on that heap of shit
14yo girls? like who. the ones who come out of ur house saying "what a stooge, cock the size of a tic tac"?
john or any of u other tossers for that matter... if u wanna say something about me, since the fact none of you know me.. get my mobile number off me, come say hi to me tonight, im 100% sure none of u cockface gerbals will say a word to me, especially u Mr speach impediment John... there are a few members on CB (namely the one in my sig) who want to take u into a back street and flog ur head in for the simple fact u dont not know how to respect a girl, nor can u lie straight in bed, u may have everyone fooled around here but every dog gets there day and urs is coming soon my friend.
Edited by EnGaGe
:verymad: NOW SEE HERE YOU LITTLE SHIT !!!!! WHERE ARE YOU GONNA BE TONIGHT I"M GONNA BREAK BOTH OF YOUR LEGS.
THIS IS NO JOKE!! I'M GOING TO FCUKEN BASH YOUR LITTLE HEAD IN
I CANT BELIVE YOU BRING RACE INTO THISS
I WILL SEE YOU TONIGHT I WILL FIND YOU AND I AINT TO KEYBORAD WARROR HERE
I AM GOING BREAK BOTH YOUR LEGS AND ARMS
hahaha caps lock is located to the left of the "A" key
for the sake of this post... i'm quoting you on here for that nice little bullshit threat.
in other terms... f**k off where u belong in one.
you've done absolutely nothing but create enimies everywhere on every forum your participated on.
so do yourself a f**kin favour, go get yourself into rehab and get a reality check, dipshit.
mil keys ftw! hey john :sick:
p.s i do believe, parent company being an american, if anything were to happen to any of their employees, shit would really hit the fan then :verymad:
hell yeah! the americans dont take lightly to their employees being threaten, abused, harassed, assulted or any of the kind.
Guest
    • As far as I can tell I have everything properly set in the Haltech software for engine size, injector data, all sensors seem to be reporting proper numbers.  If I change any injector details it doesnt run right.    Changing the base map is having the biggest change in response, im not sure how people are saying it doesnt really matter.  I'm guessing under normal conditions the ECU is able to self adjust and keep everything smooth.   Right now my best performance is happening by lowering the base map just enough to where the ECU us doing short term cut of about 45% to reach the target Lambda of 14.7.  That way when I start putting load on it still has high enough fuel map to not be so lean.  After 2500 rpm I raised the base map to what would be really rich at no load, but still helps with the lean spots on load.  I figure I don't have much reason to be above 2500rpm with no load.  When watching other videos it seems their target is reached much faster than mine.  Mine takes forever to adjust and reach the target. My next few days will be spent making sure timing is good, it was running fine before doing the ECU and DBW swap, but want to verify.  I'll also probably swap in the new injectors I bought as well as a walbro 255 pump.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
