Hi guys
I got a A31 and it has the softest suspension ever, owned a R31 before this and even that was stiffer.
Ive looked around everywhere for what suspension the ceffies take. Yes ive checked the Cefiro Substitute Parts List. But before Im going to spend the 2k+ I just want to confirm this.
1. If I buy a full set of coilovers for a S13 these are a bolt on fit? Correct?
2. Is this the same deal with the front and rear sway bar. All links etc are the same as the S13?
3. Mechanical diffs. This car is factory RB20DET so I assume R200 diff which is the same as s13-s15 and R32-R34 So I should be able to buy any mechanical diffs which were designed for these and will fit my car.
I believe you have to be carefull with the housings though as some are 5 or 6 bolt so I might have to check the housings out if I buy a second hand one thats already in a housing.
Most of these parts are easily sourced but Im having some difficulty trying to track down swaybars. Even on nissan Silvia site. What brand did you guys get and where from and how much?
Thanks heaps guys.
Sorry for the newb questions but I have been looking with the search button.
Paul
https://www.sau.com.au/forums/topic/119523-a31-suspension-other-parts/
Hi guys
Thanks heaps guys.
Paul
1. As above
2. Yes (Ask Resin for details) Whiteline make a swaybar kit and Homerrules sells second hand jap ones on ns
3. Get a brand new Kaaz diff from RMS Motorparts for R200 (Ask Huddy for details)
Have a nice day.
  • 1 month later...
Just another note. Are you guys able to tell me if R32 sway bars will fit the ceffy? Im pretty sure the fronts are totally different what about the back?
I managed to find a cheapo aftermarket swaybar for a R32 and it wont fit my car, obviously im assuming there different here then or is it the good old build quality from whiteline? (which is hopeless)
What suspension setups are you guys running?
SK would be good, but budget wont stretch that far?
I was thinking of either HSD or isc-coilovers 8/6. Would you guys use whiteline adjustable or cusco non adjustable for sway bars? Is it worth paying the lil extra for cusco or just stick with whiteline?
Cusco $700 for the pair delivered.
Whiteline I think works out to be a be around $480 or something delivered.
Regards
Paul
If you wait a bit skyline kid is getting one made up for the ceffy at the moment ....modelled off my stock one. I think its close to finish...
but if you get the s13 ones get the blade adjustable sr20 ones .......thats what i have in my car and they fit fine. but one designed for the ceffy maybe better!.
Edited by Resin
  • 1 month later...
if its fat as, then its a GTR bar... the stock ceffy bar is only sopmething like 16 mm thick... pretty average looking
Dodgy ruler measuring skills in the dark my front is around the 24-26mm mark I think.. Cheked out my mates completly stock C33 and his looked to be of simular size.. Definatly more than 16mm.
Now I'm really lost :happy:
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
    • Perhaps the answer is... more jacks!* *proper jacks must be used.
