Was thinking aqbout putting in an intercooler for my r32 gts-t.
Just like to know the pro's and con's of a front mount intercooler that runs through stock pipping vs ones were u buy or make a piping go back up to the motor via the right side of the car.
I realy dont want to cut a hole in my car, That's why im looking at the alternate options at the moment.
Thanx
https://www.sau.com.au/forums/topic/119579-inter-coolers/
blitz do a kit (well i know they do it for a 33, so i figure they'd do it for a 32) that runs back up an uses the factory piping in the engine bay. as long as you have it hooked up so that the long pipe under the intercooler is the hot pipe then its fine. the actual piping isn't much different to stock as they are usually the same size. the advantage of the piping running up the drivers side is that you have less chanse of damaging the piping. it is common for the pipe that runs back under the intercooler to get damaged when you hit something which mean that instead of just having to replace the intercooler you have to replace the piping as well. but performance wise it has more to do with the quality of the cooler more than the piping.
https://www.sau.com.au/forums/topic/119579-inter-coolers/#findComment-2203829
i don't know of any with the blitz setup that is cheap. i know there is a kit on this forum (not sure if its 32 or 33) for about $400, i think its in the group buy section. otherwise the retail on a hybrid kit is $999. but i'd say you will have to cut the hole. i think its a case of save money and cut a hole, or spend money and don't cut a hole.
https://www.sau.com.au/forums/topic/119579-inter-coolers/#findComment-2204155
you shouldnt have to much trouble with the hybrid kits if your car isnt type M. Mine took alot of extra piping and plumbing because it is Type-M (some extra bar in the way making my cooler stick out to far and the pipes not match) but cutting out the front bar is easy enough (bye bye rigidity)
I picked up the justjap kit for like $400 which is fair sweet i spose, its good enough quality (although down the bottom quite a few of the fins arent welded in str8 and are permanently mangled)
Im a cheap arse so i couldnt afford a decent one that runs thru standard piping. Cutting the hole below the battery isnt so bad, its not like a chassis rail or anything (i used a drill :)) but if u have the $ a arent so good with hacking stuff up with powertools (like me) its probably worth spending the extra $. Im on day 7 of installation but if ur car isnt type-M should only take a night or 2
https://www.sau.com.au/forums/topic/119579-inter-coolers/#findComment-2204594
If you are worried about cutting holes and stuff, why not just get someone else to install it? The people I have spoken to quote $200 to $400 for installation depending on the car and kit (i.e. what they have to modify), they will do the modifications to the front bar, cut holes, run piping etc, so much easier than trying to screw around with it yourself if you aren't too handy with tools.
https://www.sau.com.au/forums/topic/119579-inter-coolers/#findComment-2204920
look in the parts for sale section.
there is an AVO kit which uses the stock pipes in the engine bay.
the guy was asking $600 I think.
they are worth over $1100 new.
definitely worth it..
also, if you are not after more than say 200rwkw, you could buy a R34 GTT side mount intercooler.
it needs mods to the end tank which could be done for about $50 from any aluminium welding place.
https://www.sau.com.au/forums/topic/119579-inter-coolers/#findComment-2205367
Were is the extra bar on the tpye M.. Cus that's the r32 i have. If it's the acutal metal piece on the bumpa then im all good cuz i had to cut it out for the gtr front bar. I realy dont want to cut a hole, but I'm going to know and I'll do it myself.. Just dont trust other people with my car when comes to things like that. Just though some money in on a group buy on an GKtech FMIC.
https://www.sau.com.au/forums/topic/119579-inter-coolers/#findComment-2209120
Has anyone here installed one of the Hybrid GT kits or the GK Tech kits on a R34 GT-T? I'd imagine that a hole will also have to be cut on the chassis for the piping & some front bar trimmed but would the fan blades need to be trimmed as well like they would on a R33? Which is the more suitable size, 600x300x76? And is it the tube and fin thats more suitable for street cars(ie. short burst of power runs)?
Sorry not trying to hijack the thread, just thought others incl. myself would be interested in the outcome of not using std piping for a FMIC kit on a R34.
Cheers!!
https://www.sau.com.au/forums/topic/119579-inter-coolers/#findComment-2210147
the instructions that come with the kit are actually done on a r34, so yes you do have to cut blades and hole. and yes the tube and fin is the one considered better for street. but hyrbid no longer make the bar and plate according to the hybrid website.
https://www.sau.com.au/forums/topic/119579-inter-coolers/#findComment-2210195
If the Tube/Fin design is better for street use then why do people still fit the bar/plate coolers?
From my understanding the Tube/Fin flow better where the Bar/Plate cool better...
Hmmm you gave me a second thought about buying a Gktech FMIC kit as they are a Bar/Plate core... The HYBRID Gt Spec is a Tube/Fin... I dont mind paying the difference as long as its the better choice...
: CONFUSED NOW :
Edited by QRI05E
https://www.sau.com.au/forums/topic/119579-inter-coolers/#findComment-2210206
bar and plate are better for drag use as they take longer to heat up, but take longer to cool down and hold the heat more. for short bursts the bar and plate are better, but for track use the tube and fin are better. but on the street driving to work and a bit of a fang around it doesn't make that big of a difference.
https://www.sau.com.au/forums/topic/119579-inter-coolers/#findComment-2210286
another option would be to buy the gtech then buy a hybrid tube/fin cooler on its own and match the 2 up. the hybrid cooler should only cost about $300 so you basically get a hybrid setup for $700. but that is also about the same as you would pay on ebay for a hybrid kit.
https://www.sau.com.au/forums/topic/119579-inter-coolers/#findComment-2210295
I wont have the time and money to do that, thats why im asking for everyones opinion... But i think for my application the Gktech will do the job more then enough... im chasing 200+rw/kw atm... then my end goal is 300rw/kw... i think the difference between the Gktech and HYBRID is very minimal at those power levels...
Should be ordering my FMIC kit within the next week or two...
Cheers
Edited by QRI05E
https://www.sau.com.au/forums/topic/119579-inter-coolers/#findComment-2210415
Or you can do what I did and buy a second hand GTR intercooler and have the pipe work made up!
Cost my friend only $600 all up.
But if your capable like me than you can get an R33 GTR intercooler, make the pipe work up yourself (the hole required to cut has factory reinforcement around it because it's where GTR pipe work comes through standard and has been blocked off on the GTS-T - So safe,clean and structually sound! Plus the bonus I got from making up custom pipework was the 120degree to plenum set up which has been proven to cut at least 5L from the intake path = less lag) and all up cost me including getting my front bar intake hieghtend to give maximum air flow over the intercooler and resprayed = $650 = :D for a fully custom job!
https://www.sau.com.au/forums/topic/119579-inter-coolers/#findComment-2210434
$650 for a second hand GTR FMIC fitted is too much... would much rather spend $630 and buy the HYBRID GT Spec FMIC kit an at least its new with 12 months warranty...
I think the Gktech FMIC kit for $400 is a bargain and will do the job better then the GTR FMIC...
Thats my 2 cents...
https://www.sau.com.au/forums/topic/119579-inter-coolers/#findComment-2212535
    • ouch! how is the car now?I had sold my gtr but have been looking into some on trademe and a 260RS but I wouldnt be keen on any repairs needed on them
    • This sounds like someone who would have owned an R33 in their past... It's okay, I'm 100% picking up what you're putting down Mark.
    • Just back on what was raised about jacking off the the tow/tie down point on the front of cars. I've used it plenty. I've also watched it on a car where you could see it move the front end of the car. It was like the front end/whole car being tweaked and twisted a bit. I will say, I struggle to find good jacking points on MOST cars. The ones that have good points, I then normally struggle to find a jack tall enough to make the car change height!   One of my go to points for either the jack, or the axel stands though, is either a suspension pickup point, OR a subframe to chassis major bolting point. I actually think its the subframe on my R33 that has a bit of a bend in it, from being jacked in the middle too. However, it could have been one of my many other cars I've had over the years! Or it could also be the from me jacking it up, and the fact the top of the front radiator support isn't there, so it can allow the front of the car to move and bend etc.
    • My apologies. I forgot we were talking about weird beard M series stuff. Had been talking elsewhere with someone about an R33 with similar subject and got confused.
    • Nope, I don't like the look of ND RF, or any ND really, I don't like their faces or arses, why, because of their "modern" lines, the NC, whilst "modernish" has a more rounded shape that I like Well, that's how my overly judgemental eyes see it anyway
