Go and see Leon or Charlie in the Church St Deli in Brighton. Or if you have a few bucks spare, go to the Pantry next door. Parking out the front on the angle is all free. Couple of others inc Laurent and a few more further up. Deli gets my vote though.
I can vouch for Pantry. Nothing like a good morning Brekky there too! Yum! You better like dogs :cheers:
I can vouch for Pantry. Nothing like a good morning Brekky there too! Yum! You better like dogs :)
It is very nice. G/f's brother has worked there for a while now and used to work at Laurent. He is the 6'6 bloke but knows me as "Pome Al" :)
