Got a pair of Nissan weathershields for an R33 2 door that I took off my car....
I did have a buyer for them in Tasmania, but they're just to hard to post without the risk of breaking them!
Price is $100 and i'd prefer pickup in Melb (Hoppers Crossing)
I can post them, but if thats the case, it'd be at the buyers expense/risk
Pic below :D
If interested PM or email me.
Cheers
Dezz
https://www.sau.com.au/forums/topic/119869-fs-r33-weathershields/
I dun think so, but would you have one to suit R32 or would that by any chance fit...?
i'd doubt they'd fit a 32....they're factory nissan parts, specifically made to fit the 32 roof/window line...
sorry, i dont have any to suit a 32...i only have these because i took them off my car :D
nah mate, had them sold for more than that already....just didnt want to send them to the guy and have aus post break them on the way....$90+ freight, at your risk, and u got yourself some weather shields.
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
    • Hi @Chupapy i had several leaks from coolant pipes being corroded, i also had one leak on back of the head onto transmission. For me that leak was from the turbo water line. Follow the line to the back of the head The hose and metal pipe had perished these are the best pics I took of it at the time
