1999 Nissan Silvia Spec R(JDM)
Power - 184Kw
Colour - Pearl White
Mileage - 98,000kms
Tranmission - 5-Speed Manual
Have receipts for all servicing
Factory Xenon HID Lights
Factory Boost Gauge
Digital Climate Control
Factory Nismo Pedals
Blue Leather Seats
Rear Windscreen Wiper
18" wheels
Yokohama V102 235/40/18 tyres
Nissan Aero Front Bar
Nissan Aero Side Skirts
Nissan Aero Rear Pods
Carbon Fibre Bonnet
Everything else factory
Price: $22,999 o.n.o
Call 0415 807 888 or email offlist
Not interested in swaps or trades, have new car already.
Edited by jtir
https://www.sau.com.au/forums/topic/119979-nissan-200sx-s15-22999/
  • 1 month later...
Yep good spotting in the 2nd pic, wiper can be seen.
Car must go.
Price drop:
$22,999!!!
I have got a new car and this S15 is sitting around wasting my garage space. Plus everyone knows I'm whipped and the missus is giving me hard time on it.
JT
Car must go.
Price drop:
$22,999!!!
JT
Hey mate, ur in Melb or NSW???
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
