R33GT-R:
Side window D/S: $250
RB26DETT:
Lambdasond: $100 - SOLD
Con rods: $250 (7)
Oil cooler: $500 - SOLD
Fuelrail: $70 - SOLD
Gasket oilpump: $15
Blackpainted manifolds (probably cheramic coated): $100
Crank angle sensor: $40
Engine mounts: $60
Throttle linkage: $60
Clutch: $250 - SOLD
Throttle bodies: $200 (incl 3 gaskets) - SOLD
Head gasket: $100
Twin Turbo pipe: $100
Boost solenoid: $60
Coil packs: $180 - SOLD
Blow off pipe: $25
Other:
Nismo shoulder pads: $25 - SOLD
Pictures and some other parts can be found at the link below:
http://www.jolie.nu/skyline/delar/
(Australian dollars)
Edited by ThomasL
https://www.sau.com.au/forums/topic/120183-lots-of-parts/
will that oil cooler fit a 32 GTR?
Definitely since there's the same engine. You just have to find a suitable place for it. The hoses are long enough for mounting it in front of the blow off valves om my R33GT-R, so it should fit nice on your R32.
https://www.sau.com.au/forums/topic/120183-lots-of-parts/#findComment-2214233
ugot stock turbos? was after 1
Yes I have one in excellent condition. But the strange thing is that I have misplaced it somewhere. Have moved recently and have had the car at the mechanics, but it surely is somewhere. Will of course have to find it first. :mellow:
https://www.sau.com.au/forums/topic/120183-lots-of-parts/#findComment-2218003
Yes I have one in excellent condition. But the strange thing is that I have misplaced it somewhere. Have moved recently and have had the car at the mechanics, but it surely is somewhere. Will of course have to find it first. :)
well hope u find it!! wat would u be looking for it once u've found it?
https://www.sau.com.au/forums/topic/120183-lots-of-parts/#findComment-2221077
