As per the topic, My R33 GTST is for sale.
I'm in a bit of a rush to sell it as I need to get myself a work car pronto.
I'm willing to trade for a 4x4 hilux ute or similar. Must be 4WD, and must be a ute.
It's a Silver 1995 model R33 GTST
I'm asking $14,600.
2.5 litre manual turbo
85000 kms
Regular service history and receipts (post Japan only)
Parts replaced include shocks, springs, sparkplugs, coilpacks, exhaust, radiator hoses and whatnot. The car has a few simple mods - suspension, exhaust, interior bits and pieces - otherwise the boost, air intake and intercooler are all stock.
Well and regularly maintained, and I'm not happy about selling it.
Currently, 10 months rego left on it
Any queries post 'em here or call me on my mobile:
0421 270 972.
Be warned though - I don't check here that often.
Car is in Seven Hills (Sydney).
Here's some pictures for you. I don't know if it's a series one or a series two. Apparently you can tell from the engine bay or interior or something, so I've included some shots here so you guys can argue about it. It's apparently a series two.
-Josh-
Edited by joorsh
https://www.sau.com.au/forums/topic/120330-for-sale-1995-r33-gtst-skyline/
The first thing I did when I bought the car, was put it on the dyno at MRC in Castle Hill to check all of the AFR's and make sure it wasn't knocking/pinging or anything bad like that. From memory it was 170-something at the wheels. 178rwkw I think. Nothing amazingly big, but I wasn't expecting it to be either, seeing as the car has only small mods. Not a whiff of leaning out or knocking either - it was perfect for lack of a better word. I'll try and dig up the dyno sheet for you.
Edited by joorsh
    • forgot to mention that when it does this it does not kill the engine, but I have not kept the pedal down long enough to let it, as I see no reason to beat up on it as its got to be something simple, small and dumb causing this.  And as soon as I let off pedal, the engine returns to its normal super smooth operation and rpms re-stabilize quickly, once below 4k.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
    • Shimmed or shimless, still solid, no hydraulic pump up stuff.
