Hi guys need to advice please.
I got a SAFC in my car and i did a very silly thing. I just want to know the perofrmance difference between tuned SAFC and factory setting .(When i bought the car it already came with the SAFC with tuned setting)
So i press "initialize", then eveything should be back to normal/factroy setting right....then turning the ignition off & on again.
However, the TCS light and Slip light come on all the way when my car was ideling.
Then i enter the tuned data setting into the SAFC again. guess what happan? I was unable to start the car, it was started like 1 sec and then off. and the engine light was on all the way.
I wonder what's going on? Any idea guys?
Now I'm scare to drive out now as the TCS and slip light on all the way. I wonder how could the SAFC deal with the TCS?
By the way do you suspose to enter the data while the car is ideling?
cheers
steve
https://www.sau.com.au/forums/topic/120401-need-your-help-who-has-safc-please/
did you enter in the 2 options in the ETC menu ? you might not need to.. but double check i guess..
Not quite understand what you mean by 2 options in the ETC menu bro?
Is anyone is here know how to uninstall the SAFC? Or if i bring to the car to garage and let them to do it how long it's going to take?
cheers
steve
Ummm doesnt that mean you cleared the tune that was on there? and your now gonna have to get it retuned?
Now the SAFC setting is back to the factory setting. And i don't want to retuned it as i already got the tuned data on my car.
The problem is even i enter the tuned data into the SAFC, there still have problem..... the engine light will pop up.
And if i use the factory setting, the TCS light and Slip light will pop up.
So i really don't know what to do ay.
By the way how long it's going to take to uninstall the whole SAFC by the garage?
cheers
steve
    • Ironically the GTT was quite reliable in the 7 years of ownership. From memory I've only had to replace a radiator and coilpacks out of inconvenience
    • Yes I can see how that would put you off HFM, especially with the price of good quality brake fluid. From what I understand it as you say the BM50 is the standard BMC for a R32 GTR, I must admit I would like to go far a Genuine Nissan BM57, but lack of cash prevents that at present. With the price being so close between the genuine BM50 and BM57 a BM57 New it seems a better choice as you gain that 1/16 bore size with the BM57, I would be interested in how much difference you feel with the BM57 fitted. I am going to take SteveL's advice in the short term and see how much actually comes out of that proportioning valve vent and save up for the Genuine Nissan part. Thanks for clarifying the HFM failure
    • Thanks mate. I just got the post inspection 1/2 done from state roads when the starter motor packed up, either that or the car alarm system is having trouble.  OEM part number 23300-AA112.
    • Hi, I though I was coming to an end in finding a replacement starter motor for a rb25de neo. I came across a starter motor from Taarks and a message below stating: Direct fit. 11 Tooth count. All below part numbers have been superseded to 11 teeth. Can some body shed some light on going from 8 teeth to 11 teeth apart from 36-month / 25,000 km warranty for passenger vehicles to 12 Month Warranty. Compatible with the following Nissan part numbers: 23300-20P00 23300-20P01 23300-20P05 23300-20P10 23300-20P11 23300-AA111 23300-AA112 23300-AA300 23300-08U10 23300-08U11 23300-08U15
    • Low battery? Maybe check capacity? I know first-hand, on BMWs if your battery drops below 80% capacity, it starts causing strange issues.
