I have a exsisting xforce turbo back set up. The dump and front pipe in one is 3 inch. Since im getting a high mount set up, I need new ones fabricated in 3.5inch. Any idea as to how much this will cost? Also the cat is three inch so should i get a larger size too? Im thinking of just hollowing it out instead
https://www.sau.com.au/forums/topic/120541-300rwkw-with-3/#findComment-2221162
well if your only running 3" after the cat .. i would run 3" before the cat too ...
im running 3" from turbo back, running stainless custom with an xforce muffler..
cost me $1100 including the new cat..
remember hollowing out the cat with induce flames on the overrun etc, and will potentially melt stuff, as well as be very illegal ... big fines and EPA tests etc.
up to you on that bit. i say dont do it
https://www.sau.com.au/forums/topic/120541-300rwkw-with-3/#findComment-2221197
I had no cat on my rb20det sil-80, i fabbed up a piece of pipe same length at cat with two flanges and put that inbetween, had some mad flames. I kept the full proper unbutchered cat in garage, then when i sold the car i put it back on. I had it intended if i got sent over the pits at qld tpt, before i went i would put cat back on. Cops couldnt see, cause car was too low anyway. That was back in my young silly days hehe.
I hear the metalcats/magic cats are supposed to flow really really well.
https://www.sau.com.au/forums/topic/120541-300rwkw-with-3/#findComment-2221456
Have the guys using full 3" exhausts dropped them from the dump and seen if there is a power increase at all?
So that they can definately say there is no gain?
hope u got ear muffs when she's on the dyno, that would be bloody loud when she starts to boost!
https://www.sau.com.au/forums/topic/120541-300rwkw-with-3/#findComment-2225702
As a general rule, a 3" exhaust is good for 600 engine hp. That equals around 380rwkw.
As for running larger dump pipes. There is absolutely no need in running anything more than a 1/4 inch larger diameter than the turbine wheel anyway. Any of the 600hp turbos out there should have a fairly large turbine wheel and a 3" usually goes straight up. 3.5 inch is just stupid unless you are chasing 400rwkw or more.
https://www.sau.com.au/forums/topic/120541-300rwkw-with-3/#findComment-2225878
What rule?
I've seen cars aroun d the 330rwkw mark change to a 3.5 or 4" and pickup another 20rwkw and lots of midrange.
380rwkw & 3" is sus
https://www.sau.com.au/forums/topic/120541-300rwkw-with-3/#findComment-2226313
Forget about 3 or 3.5 and worry more about the cat + mufflers.
I have a DoLuck 3" cat-back exhaust which has flowed 328awkw without any problems but was so loud and droned so much you could hear me from 2km away.
For a noise reduction quickfix I got a local muffler place to bolt on a quieter muffler. Whilst my exhaust is now quieter it is sooo restrictive that my boost level is all over the place and the engine just doesnt want to rev above about 5000rpm, at a guess i'd say i've lost an easy 50rwkw (I can hear the massive back pressure just on idle).
The DoLuck canon is basically a massive straight through pipe with baffling around the outside (which does... nothing). The quiet muffler has all sorts of baffling channels around the inside channeling the gases all over the place to help reduce noise, but created a massive restriction.
Edited by benm
https://www.sau.com.au/forums/topic/120541-300rwkw-with-3/#findComment-2226332
What rule?
My rule.
And that would be the same rule they use to design turbos and rate them accordingly.
A 3 inch exhaust is enough to sufficiently remove gases from an engine producing 600hp....this is roughly of course but is a good general indication of the system you will require.
In most cases the swap to a 3.5inch would see a gain only in the CAT upsize as this is the largest restriction. Unless the people who made the 20rwkw gain aren't running a cat. It would be silly to say 'oh I've got 380rwkw so I should be good for a 3 inch system' Just because your injectors flow at 550cc or 700cc, doesn't mean you run them at 100% because they can flow that. Anything around the 350rwkw mark and you would automatically upgrade to a larger size.
https://www.sau.com.au/forums/topic/120541-300rwkw-with-3/#findComment-2227571
I can say yes i have tried this and i didnt gain any HP at the wheels but did gain 30 lbs of torque
I run a Single 3" exhuast with a punched cat on my skyline and its fine. Making 400 kws or so with NOS
Exhausts vary on Engine Size,Cams,Turbo Size & amount of boost.
https://www.sau.com.au/forums/topic/120541-300rwkw-with-3/#findComment-2227698
    • Yea got me coppers. Bad news is I just put them in and the car still has the light and shakes. I also noticed I hear like rattling coming from the exhaust piping right under me. Does 21 also have a possibility of being O2 sensors?   So, coil packs are good, the harness is good, the MAF is working, and obviously the spark plugs just replaced and working.
    • Make sure you drop the GTT base tune back in, and set your injectors again, this will remove anything playing up with it you may have removed. Possibly lean there as it's normally a fast transient going THROUGH atmospheric pressure, and a turbo motor would then quickly go richer as boost builds. The only worry you MIGHT have is ignition timing, as the DE is higher compression than the DET from memory. But again, you're not in boost, so the DE motor will be a lot more forgiving at atmospheric.   Get Murray, Kinkstahs, and Johnny's input on tuning haltechs, those guys have played with tuning enough in the past to be able to help now you're past the trouble shooting stage of the MAP issue
    • @Rusty NutshI mate. Do you have a pinout diagram for the na neo auto ecu?
    • Yeah thats the plan now. 🤞
    • Have a chat with the tuner, you'd want to drive the car straight there.
