Hi Guys have the following parts from My r32 GTS4 rb20det for sale :D, as well as many new parts. Your welcome to come have a look before purchasing, i am located in adelaide, if interstate i can get you a freighting quote. Any Further Questions just ask!
rb20det inlet plenum (polished), injectors, fuel rail, fuel reg, cold start actuator,tb, tps, $200
rb20det stock dump pipe $20
rb20det stock front pipe $30
rb20det AC compressor $50
rb20det AC bracket and belt tensioner $30
rb20det rubber intake pipe $20
rb20det turbo heat shield $10
rb20det timing belt brand new $30
rb30 head gasket MONOTORQUE brand new $30
rb30 Sump Gasket brand new $20
rb20det power steering belt brand new DAYCO 4pk0940 $20
rb20det spoiler with brake light, marone in colour $120
HKS turbo elbow pipe with silicon rubber $100
R32 Intercooler Very good condition $100
Cheers FOOLBOOST
PICS UP SOONISH :)
MORE PARTS ADDED!
Edited by AM-PERFORMANCE
https://www.sau.com.au/forums/topic/120553-rb20det-parts-much-more/
I'll take the head-manifold intake gasket?
I'm also interested in the intake manifold if you will seperate the upper polished part from the intake runners, IAC fuel rail and injectors etc. I only need the lower part to make a plenum from.
Cheers,
Ian
Cheers,
Ian
Ian im not sure what you mean do you mean just the gaskets or the head, and manifold intake gasket, one of the gaskets goes in between the plenum and runners where as the other attaches the runners to the head, posted some pics of the head and plenum top half.
  • 1 month later...
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
