  • Replies 63
Go the shopping list!! Hahaha!
I went past Hoyts today to try to get times:still nothing! They say at midnight tonight they should have times up:I'll check in the morning...
man the rav is nowhere near as sick as the "FULL SICK HYUNDAI MAATE"
for those not aware i've been religated to driving a 4cyl 4spd auto korean land barge that reminds me of driving a lounge chair, except slower and with less responsiveness.
*throws hissy fit!* I WANT MY GTR BACK :P
its now proven that there exists no worse withdrawal symptoms.
d
And I thought 'smackies' coming off 'the gear' was a low point,LOL!
Righto:Hoyts have the sess' times up:we're there at 7.15pm-I'd suggest get there way earlier for tickets,as Thursday release nights always prove to be busy,regardless of movie genre. See you there! J.
ill bring the all powerful courier ute, its a 2.6L!!! same as the GTRs!!!! get there at 6? is there a meet "spot" i dont know what most of you look like and would hate to be by myself :P
Edited by low200
Alrighty, I'm meeting Luke (Frink) out the front of Hoyts at 6pm, to get tickets for the 7:15pm showing, given that it's opening today it'll probably be fairly packed so we're thinking we'll get our tickets a bit early.
Anyone that wants to meet us there then is more than welcome to.
We'll probably hunt down some form of dinner in between 6 and 7:15 as well.
Edited by Bluprint
ok, well me and a couple of other mates are going to the 930 showing, cause thats the only time some of them can make it ..
so i guess there will be potentially 2 SAU sessions :P
we are getting there at 910 to get tickets for 930 show ..
Cheers,
-JD
PS: Hope it rains tonight :P:D
Edited by JD-33
    • yeh they are 235/45/17 up front and 255/40/17 in the rears. I still didn't get my answer if i can fit a 18x9 up front. I want to get 4 of this and see if they will fit before committing as they didn't see an 18x8 as an option but there is a 18x9.5 also.   Enkei RS05-RR 18x9 35mm ET 5x114.3 75.0 Bore Matte Gunmetal Wheel
    • This. The R34 handbrake icon DOES come up when the brake fluid level is low. You might be sitting right on that threshhold. I have been down this diagnosis path and this was the solution (and it was pretty much as full as your picture is to begin with).
    • Unfortunately the cavaet to that is that while any scan tool should be able to read the code, the workshop will need a consult plug to OBD socket adapter. You don't have a location on your profile, where are you based?
    • @Haggerty this is your red flag. In MAP based ECU's the Manifold pressure X RPM calculation is how the engine knows it is actually...running/going through ANY load. You are confusing the term 'base map' with your base VE/Fuel table. When most people say 'base map' they mean the stock entire tune shipped with the ECU, hopefully aimed at a specific car/setup to use as a base for beginning to tune your specific car. Haltech has a lot of documentation (or at least they used to, I expect it to be better now). Read it voraciously.
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
