Hi everyone,
just wondering what are the main reasons a car can run a bit rough, especially on idle?
i've recently replaced both coilpacks (to Splitfires) and spark plugs (to NGK Iridiums) on my 34 and i noticed on idle it's still running a bit shuddery, i guess the best way to explain it is that when you're cold, you sometimes just shiver, well it feels like the car will just shiver/shudder every now and then on idle...
sounds a bit noisy (i know, very vague) when driving as well, are RB engines on the noisy side? grown up with BMW inline 6's, and they are smooth as anything so that's my comparo engine type.
Car has 51,000km's on the clock, no idea of validity of that (98 Car) - don't think timing belt has been changed.
Car ran for a short time on 5 cylinders, when one of the coilpacks died. So i've been told that the fuel would have been going around that cylinder and could potential wear off the oil, etc... not sure.
Don't think has had oil change since compliance (bout 2,000km's since compliance) not sure if they changed it though.
Just wondering what are the main reasons a car would be a little rough running that's all?
cheers,
daniel
https://www.sau.com.au/forums/topic/121027-reasons-why-a-car-runs-rough/
Do a 100k km service on it.
Do everything that you should have done when it first arived. Engine, gearbox, diff oils, all belts etc.
Just do it for peice of mind. If your still having trouble after that, then come back and ask whats going on.
well it had a semi-service when i got the road-worthy - i asked the guy to check oils/filters - he said filters were fine, oil was not too bad, he said maybe 1 month get it changed. I don't know if you can check belts?
and since then have now got brand new coilpack and sparkies - i'll have to double check what the compliance place did.
so it's been looked at and such but i suppose you never really know the km's...
i've also been told that changing oil won't make a car run smoother, or cause it to be rough?
My car pops every say 20 seconds when its idling, nothing too major, just a bit of a pop. I dont really care about it as its just a slight missfire. My mates R33 does it to...
If thats all you're woried about then you've really got nothing to worry about.
Mine does a slight misfire on idle every 5 seconds. Only started happening after I had problems with a coilpack (fixed now). It doesn't misfire once its off idle.
I've decided to just ignore the problem, but I wouldn't mind trying something if anyone knows how to fix our problems. :blush:
I too have been chasing this problem as i thought it to be coilpack related. I've changed plugs (ngk iriways), splitfires, taken off the afm, throttle body and ISC valve and cleaned them to no avail. The only thing left for me to do is get the injectors cleaned ultrasonically, change the fuel filter, double check my timing at idle, and change the 02 sensor, which i'm hoping is the culprit - i've been told the 02 sensor controls rpm at idle, not the afm.....
Give the AAC valve a clean, the R34 type uses a vibrating stepper motor to adjust the airflow, my one seized shut with dirt and bollocks a while back, that led to a constant high idle.
Also having the A/C on for a cold start gives me a feeling similar to a dodge coil-pack when it first runs in the morning, once all warmed up it stops...try running with climate control off and see if it's fixed.
faulty tps? what's tps?
no exactly sure what some of these aac/isc valves are etc, but it's all noted.
O2 sensor... well it's easily done more than 40K
in regards to the "popping", i've had the car parked, bonnet up, just to have a listen and every now and then, maybe every 15-20 seconds, i'll hear a 'pop' i guess is the best way to describe it. you can't hear it from the inside with the doors closed, but with the bonnet up you'll hear a pop, sounds like it's coming from the back of the engine bay, not 100% sure. It's probably not really a pop, but like when you turn a gas stove on and you hear the ignitor going, 'tick' 'tick' 'tick'... it's kinda like 1 of the 'ticks' and that's it... because i'm not in the car at the time, i can't tell if the car shudders when it 'ticks'...
*sigh* i dunno.... i'm annoyed i don't know how to check/do all this stuff myself, need to know more about engines..
tps = throttle position sensor, tells computer the percentage of throttle applied
popping = missfire, most probably a spark issue - plug or coil, check gap and also for cracks in coils, if there is any cracks cover them with araldite and allow to set, araldite does not conduct electricity or alloy it to pass, much better fix than the tape most people are using. (my friend who is a mechanic thought of this and fixed his coilpack problems on his 1jz soarer) mechanics are great friends haha
if it is more an unsteady idle probably be stepper motor, clean it and see, also take the throttle body off and clean the throat and butterfly and all passageways with throttle body cleaner/carby clean (careful with carbie clean make sure it is throttle body safe some etch away at the alloy) my car was really rough at idle and cleaning these parts fixed it. hope this stuff helps.
I'd love to know how the mechanic managed to check an oil and/or fuel filter.
They are both sealed, non servicable parts.
Time to find a new mechanic.
perhaps he checked the oil by pulling out the dipstick to look at the colour and possibly the smell of the oil to determine its life
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around with a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
    • Yep, this bit another local owner. I caught it before putting the transmission back into the car, what I noticed was the pressure plate fingers weren't flat and even. It's more obvious with the pull style clutch because the throwout bearing ring was visibly not flat once everything is put together. Nismo should really update their instructions to call out this specific detail. I'm not even sure the clutch as-shipped orients everything properly.
    • It ended up being that orientation of the float hub in relation to the clutch disk, when I installed it, I heard a loud click and being stupid, I decided to not take it a part and check it. The hub didn't properly align with the clutch disk and was causing the issue. Definitely an odd one! Dahtone Racing was able to fix me right up, stand up blokes!
    • Right, but I'm saying on the stock ECU measured airmass from the MAF is no higher than stock. So it's accounting for the higher flow rate iso-manifold pressure. You just have to keep turning down the boost until you're within the stock tune's load scale. If you run off the end there's no telling what will happen. This does mean there's zero benefit to the turbos you're running vs stock, if anything it's just a straight downgrade because the transient response is worse, you don't even get the ECU's boost solenoid helping to pull the wastegate closed during initial spool, and peak power is only whatever the factory map can give you before you hit the R&R corner. On a -9 I would bet that you would have to change out the wastegate spring once you have a real ECU and you're tuning it for real. I'm not saying this is a remotely ideal state of affairs, it's just a way to keep it driveable until you can get a proper tune done.
