Hey guys,
Yes, yet another front bar question.....anyway.
Has anyone ever seen these lights actually working on a R33 before. I'm talkin about the little white lights on the inside of the idicators. I know there is wiring going to the whole light unit but I just wanna know if they can be used or if someone has seen them working on another R33?
https://www.sau.com.au/forums/topic/121044-r33-m-spec-front-bar-parking-lights/
good question.
mine dont work.
although i am missing the FOG LIGHT relay in my engine bay fusebox.
Could that be why?
When i switch on my parkers (low) lights, the dim lights in the headlights turn on, but no others.
Yeah i wired mine up on my first R33...
I bought a series 2 indercator stalk and wired the relay to the fog light switch on the S2 stalk.
Easy done... Didnt do anything really...
Series 2 front bar with fog lamps is a far better idea.
Actually, i found another thread that explains all this.
R33 S1 had fogs as an option. S2 came standard (i think).
So there are actually no lights in there, just a clear lense. This explains why i have no FOG relay.
Are the fog lights like parking lights (dim) ?
Or like spotties?
I have a pair of spotties on my front bar. Bright as hell. I think they look ok.
Wouldnt bother with the standard fogs, especially for the extra hassle of installing bulbs etc.
Hey, those look alright Munkyb0y, have ya got a pic with the fog lights on?
They might just be the answer to my lighting problems. :)
I'll post a pic soon. Havent got one right now.
These lights are really bright, like high beam+ bright.
I put bulbs into the standard assembly. I just used a parker bulb 5W. If you use anything bigger you will melt the lamp assemby. They simply were not made for fog lamps like the Series 2.
Does not really matter cause fog lamps are only surposed to be used in high beam conditions.
Here's a pic with the lights on.
It's an old pic, havent had time to take another one at night.
These lights are very bright, and only meant for high beam use, as Col-GTSX said.
They have led's in them too. And a switch box under the dash to change the colours.
Nice novelty, but I dont use it, they were on the car when i got it.
by the way, these arent my real plates, duh!
They look pretty good mate.
Only problem is, finding a spot for them in my front bar without blocking the fmic.
I wish i had that problem. :(
Your bar looks pretty damn nice.
It's kinda similar to mine, sorta, but doesnt look quite as low.
Do you have issues with driveways and speed humps etc?
Mine's way too low. Got stuck in a carpark the other day, exit ramp was too steep, had to go out the entry ramp. :D
What type of bar is yours?
Been looking at changing mine.
    • I will rebutt this and the preceding point from Dose....but without doing any calcs to demonstrate anything and without knowing that I am right or wrong. But... The flow capacity of a fluid transfer system is not limited by the smallest orifice or section of conduit in that system, unless it is drastically smaller than the rest of the system. OK, I use the word drastically perhaps with too much emphasis, but let's drill down on what I really mean. The flow capacity of the system is the result of the sum of the restrictions of the entire system. So, to make an extreme example, if you have a network with 3" pipe everywhere (and let's say a total length of only a few metres) and that 12mm ID restriction of the oil filter connection being the obvious restriction, then for any given amount of pressure available, the vast majority of all the pressure drop in the system is going to occur in the 12mm restriction. But.... increase the length of the 3" pipeline to, say 1000m, and suddenly the pipe pressure loss will likely add up to either be in the same order of magnitude, possibly even exceeding that of the 12mm restriction. Now the 12mm restriction starts to matter less. Translate this to the actual engine, actual oil cooler hose sizing, etc etc, and perhaps: The pressure loss caused by flowing through the narrow section (being the 12mm oil filter port, and perhaps any internal engine oil flow pathways associated with it) is a certain number. The pressure loss through, say, -12 hoses out to the cooler and back is negligible, but The pressure loss through -10 hoses out to the cooler, at the exact same length as the above, starts to become a decent fraction of the loss through the 12mm stuff at the filter port. Maybe even it starts to exceed it. I could actually do these calcs if I knew 1) how much oil was actually flowing in the line, 2) gave enough of a f**k to do things that I hate doing for work, voluntarily for a hypothetical discussion. Anyway - I reiterate. It's not the narrowest port that necessarily determines how much it can all flow. It is the sum. A long enough length of seemingly fat enough pipe can still cause more loss than a semmingly dominant small bore restriction.
    • To pick up what Dose is putting down. Not a lot of point running a huge hose if the motor is still restricted to the smaller size... It's only capable of flowing so much at that point...   *Waits for GTSBoy to come in and bring in the technicalities of length of pipe, and additional restriction from wall friction etc etc*
    • Hooley Dooley these things have some history! If i sell them they will need a certificate of providence to prove they have been in the hands of verified RB20 royalty! They have been stored in a plastic tub, away from sunlight and moisture. They are in mint condition. And they will stay that way, as i have sprung the money for a set of shockworks coilovers. I'm just working on getting them in at the moment, after rebushing the rear of the car, and while the subframe was out i welded in the GKtech reinforcement bracing as well.  They will get a workout at Ararat King of The Hill in November. I ran 48s on the short course there a few months ago, and i am hoping with new bushes and shocks in the rear i can launch a bit harder. There was a fair bit of axle tramp when i tried too hard off the line. a few of the corners had dips mid way which also made the car feel a bit unsettled, hopefully this will help there too.
    • Food for thought, the stock oil filter thread is a 3/4-16 UNF, which has an ID of about 10 to 12mm (according to ChatGPT lol). Now compare than to an 10AN, which has an ID of about 14mm (Raceworks is 14.2mm, Speed flow is 14.27mm).
    • Yep, totally get that. However hooking in for Generator back up is only a few hundred bucks for the wiring. You could put a couple of those in (for different circuits explicitly) and run a couple of baby generators. Bonus, you can balance them across different circuits, and now have backups in your backup. I'm looking at buying places that won't even have water etc, and I don't mind the idea of getting off the electric grid either, even with everything you've said. This country already has enough power outages that even the mains grid isn't that reliable anymore. I do agree though on spending a bit more to get better gear, and to add some extra redundancy in to the system too.
