Most of the members of this forum have known for some time my father has been ill.
Well today was his last, it's over, as he past away early this morning.
I'm not looking for sympathy, as I have had time to prepare.
I just want you all to know that any irresponsibility in my actions in the near future could have a reason behind them and I apologise if it happens.
I just want you to understand why.
Thanks,
Dennis
https://www.sau.com.au/forums/topic/121106-my-father/
Dennis mate, I'm sorry to hear that he has passed.
Take each day as it comes and things will get easier as they pass.
I am sure that in time any forum "irresponsibility" caused by this will be forgotten, but I am also sure that you will still be a passionate Old Bugger when it comes to your Nissans for ever.
Warm Regards
Wardie
https://www.sau.com.au/forums/topic/121106-my-father/#findComment-2232310
Warm Regards
Wardie
And thats why we love yah :rofl::D
https://www.sau.com.au/forums/topic/121106-my-father/#findComment-2232574
    • About $4k brand new, available from vendors in Oz, or via an importer from Japan. Although that is for an R34 box, so you also need to buy the push clutch front plate (brand new from Nissan) and swap that over, and drill the bellhousing for a push clutch slave cylinder.
    • Absolutely could be. I collected data logs from when the O2 sensor was still out and also after I had replaced it so will try to compare them. Pretty confident that the affect is lowered with the new sensor, will check logs at the same RPMs/conditions.
    • Hey guys Long time lurker, I daily a nm35 stagea 250t rs four and I've had it for almost 2 years (very reliable 👌). Issues or just looking for information ill always find myself here having a read, so thought id join.  3inch stainless intake, pod filter, AM performance turbo dump pipe, 3inch hotdog, 3 and half inch stainless to 3 and half inch AM performance blast pipes. Bc racing coilovers. 18inch rims Hdi intercooler and trans cooler soon.  Here's my car
    • thanks for the advice on the box... i was thinking the 6 speed was better for cruising on the highway but on closer inspection and comparison the Rb 5 speed box was not too different...  So the choice is going to be the RB25 box... if I can save up and find one at the right price
    • Thanks Matt, yes that's what i am aiming for. Just going to apply the right voltage and grounds to the dash connector. Hence my search for these pins... any chance you know if these pins are in the same spot as the ones on the S15 Dash connector? as mentioned above on page 8?
