Hey all,
was down at commercial polishers and they quoted me $800 to polish all four rims..
I have works meister s2r, they are deep dish..
Do you think that is worth it?
he also said just to clean and dip in acid, would be $140..
anyone know any other places?
I need to clean my rims.. brake dust and melted rubber are all over them.. :D
https://www.sau.com.au/forums/topic/121153-rim-polishing/
maybe try Elite plating... they *MIGHT* do polishing seperately as well. They did a lotta polishing for my dad's classic he was restoring, but he also gave them a lot of chroming business so unsure.
Try em anyway. :D
Elite Plating
2 Kiwi Crt Lonsdale SA 5160
ph: (08) 8186 071
https://www.sau.com.au/forums/topic/121153-rim-polishing/#findComment-2232659
Hey Maxx,
Areyou sure polishing?.. or just acid dipping? Or am I just getting ripped.. coz that's the same place I got my quote.. mind you..I did roll up in the skyline..
maybe I should phone and ask...
Commercial Metal Polishers
372 Martins Rd Parafield Gardens 5107 (08) 8281 7033
got told by other member this guy can polish a rims for $50
no personal exp. tho
https://www.sau.com.au/forums/topic/121153-rim-polishing/#findComment-2232734
I had a set of Magnums polished by this guy for $50, but that was like ten years ago!
https://www.sau.com.au/forums/topic/121153-rim-polishing/#findComment-2234413
Yeah that sure sounds a bit rediculous. Try this mob
EXTENSIVE WHEEL SERVICES
307 South Rd Mile End 5031 (08) 8352 5777
I had both my front rims scraped & it cost $88 each to get them both polished back, though they're not a deep dish. I wouldn't think it'd cost a hell of a lot more to do yours, give them a go. They did a great job, would never know they were ever near a kerb.
Also try Adelaide Wheel & Rim just accross the road from them. I had 1 of mine fixed under insurance & extensive was the place they sent me to. So I don't know what these guys are like.
Edited by Electro
https://www.sau.com.au/forums/topic/121153-rim-polishing/#findComment-2236936
Yeah thanks every one for their input.. I'll do a bit more shopping around..
It's not that DIY option is beyond me..just that I don't think it'd give me the same outcome..
I saw the polish the guy did and it virtually looked chrome..
So I wonder if these other places do the same..
This time I'll prolli chuck the rims on the back of a ute and bring them in..haha.
cant reach you so read this, re: mate who got it done
$250 set of 4
polished inc. fixing gutter scratches
mobile service 0417853047
https://www.sau.com.au/forums/topic/121153-rim-polishing/#findComment-2241916
