Specifically suspension, subframe, brake and other drivetrain photos and info from the likes of the Gibson Motorsport R32 race cars. Engine mods (and cheats...?) info. Anything from the golden era of Skylines in national and international circuit racing. Thanks.
Maybe this help a bit?
groupagtr.pdf
Some suspension and under body photos;
My favourite, rear LHS note the HICAS dissabled via the replacement bar (no steering rack).
The rear brake ducts
Some more pictures to come
:ermm: cheers :D
Edited by Sydneykid
The Bathurst spec fuel system in the boot. The two large cylinders either side are the dry brake fittings for refueling.
The mechanical (high pressure) fuel pump was driven off the inlet camshaft
The fuel rail, injectors and inlet system (note the standard throttle bodies and fuel rail)
More pictures to come.
:P cheers :D
Edited by Sydneykid
The coolers, in Bathurst spec it had 7 coolers;
Rear diff
Transfer case
Gearbox
Engine oil X 2
Radiator
Intercooler
The Gearbox, Transfer Case and Rear Diff Coolers
The RHS engine oil cooler, there was also one similarly placed on the LHS.
:P cheers :D
Edited by Sydneykid
thats the most awesome skyline of all time i reckon, love the quality of the finish of everything on that thing :D
just wondering whats that little round plate on the side of the plenum for? is it a burst plate incase it overboosts?? similiar to the ones on the supercharged doorslammers, etc?
that car looks like sex on wheels :P
cheers for the pics sk, anyone got any others???
what sort of turbos were they using in those days? n1's or something bigger and better? anything equivilant to todays style turbo setups like 2530s, etc? or bigger?
what sort of hp at wheels were they putting out? i remember reading over 500hp or something?
Edited by CruiseLiner
Yes, they were sure nicely made, Fred sold a couple to customers, around $300K was the rumoured going price. That's equivalent to $650K in 2006 money.
The turbo's where the unbiquitous steel turbine "Group A's", as per the regs.
Due to their total dominance, CAMS limited the boost and made them fit a blow off valve. That's what the round plate on the inlet plenum is for.
They first appeared with around 550 bhp that quickly grew to a bit over 600 bhp unrestricted. Then dropped to ~475 bhp with the boost limit.
I do have some more pictures, but they don't really show anything that isn't shown in the above selection.
:) cheers :D
Great pics, thanks for sharing! A few observations:
Whilst someone posts on the build quality, it may have been awesome back then, but now we have the mega spending of teams like the DTM and WRC cars, ducts are vac moulded in carbon, roll cages are far more complex and efficient, brackets are milled and anodised, the whole shebang is costlier and "prettier". How times, expectancy, and spending have changed! :(
What is the ecu (HUGE....) that they ran?
Any detailed pics of engine water cooling mods? Here in the UK some of the best known RB26 tuners take steam pipes from the water gallery pipe that runs parallel with the intake plenum, back to a swirl pot, to take any steam pockets from the head. Hard to see if that's the case in these photos?
Whats the header tank in the RH bulkhead corner of the engine bay?
The low pressure side of the fuel system, in the boot, looks heavy and complex, is this because everything has a back up in case of failure?
Did all the Group A cars run custom suspension links, hubs and uprights?
If not, how was rear bump steer, which from my mesurements on a stock R33GTr and GTS-t, dialled out? It appears a lot of toe in on rear roll is engineered into the stock rear suspension, and is proving undesirable to me.
Finally, roughly how many proper Group A and JGTC Skylines were built, and although I see quite a few R32's in photos, of course, and some R34's, it seems that the R33 was never represented in such numbers? Do many come up for sale in Oz?
Thanks again for posting all this. More very welcome!
Whilst someone posts on the build quality, it may have been awesome back then, but now we have the mega spending of teams like the DTM and WRC cars, ducts are vac moulded in carbon, roll cages are far more complex and efficient, brackets are milled and anodised, the whole shebang is costlier and "prettier". How times, expectancy, and spending have changed! :laugh:
Hi Chris, sure there is a change in materials used, but the quality of the fabrication, regardless of materials, is the impressive part.
1. From memory the ECU is an Electromotive, they also made the Nissan ECU’s for the LeMans prototypes
2. The water head tank is located just in front of the RHS strut tower. It has 3 connections, one to the cylinder head and 2 to the radiator. Note that the radiator was mounted lower so as to give room for the airfilter box and ambient air feed for the turbos. So the high mount header/filler tank was necessary.
3. The fuel system is the endurance race spec, so it has back up/redundancy system plus a 2 lap reserve with a lower pick up in the tank.
4. The Group A regs allowed modifications in the suspension arms. Conceptually because they were running slicks it was considered a safety issue. The standard components may break under the loads.
5. Bump steer (front and rear) was zero over 80 mm of sprint race suspension movement. I know the endurance race spec was different due to the weight of fuel.
6. I believe the Gibson guys made 5/6 in Australia, 2/3 for overseas customers, 2 team cars and 1 local customer car (the GIO/Windscreen O’Brien car). In Japan I saw one grid of over 20 X R32GTR’s in the one Group A race. The ones I have seen overseas are not anywhere near the Gibson standard, they were considered by Nissan to be the best in the world.
7. From memory Group A was discontinued by FISA before the R33GTR was released, so I don’t think there are any Group A R33GTR’s. SuperTourers took over in the rest of the world and V8SuperCars here.
:) cheers :D
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
