Hey Guys,
Just wondering whats the going trend in wheels for Lines @ the mo i tried to source a set of Advan RS and i think RGII's for my line but found the to be quite expensive (altough i new they would be but damn that much!!!)
Neway im going to be selling my 18" vault savanah's soon as im looking to upgrade to 19's or 20's...
My car is a Black 95 Gts-t
Any ideaS???
https://www.sau.com.au/forums/topic/121388-im-a-loss-what-wheels-do-i-buy/
dont follow trends, get what you think looks good...as long as it isnt big chromies....i f'ing HATE big chromies lol, they LOOK LIKE PLASTIC !! most do anyway, there are a FEW exceptions...
First of all good choice on getting rid of the vaults haha, those rims and any other big chromies makes the line look cheap. Going bigger then 18s would kill the ride comfort and also your wallet for tyres. I would rather go for 18s but hey its your decision, if you rekon bigger is better ther go for it mate. Check out konig unknowns on the ozzytyres site they would look nice on a black line. Weighing around 7kg per rim but heard they are quite expensive.
19's DO NOT LOOK OUT OF PLACE on R33's.
But you will loose low end torque and top end power, get about 50km less per tank, and probably loose a little handling. Comfort is the SAME as 18's provided you get the same profile, ie:235/35/19.
19's are purely just for looks, everthing else stick with 18's :) That's why i have a spare set of 17's, for track, spirited cruises and dyno days.
I would stay away from 20's!
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
