Hi guys,
A few people I know have asked for some posters of their cars. Here are a few of the prints I was working on last night (resized ofcourse).
The prints are professional quality poster sized prints, slightly larger than A3. I'll take a photo of the prints once I've received them.
But yeah, if anyone's interested in prints or a shoot just send me a PM.
Cheers.
https://www.sau.com.au/forums/topic/121417-worked-on-some-photos-for-print/
get my car out of your signature :)
Correct! I'm betting you didn't ask before using this image in your sig, so you should take it out, KLowN.
I'm sure that if you'd have asked BEFORE you used the images, then Sl!m would either:
a - not have a problem using it if you credited him with it being given to you, or
b - Sl!m would most likely have pointed you in the direction of where you could get one for yourself PROPERLY.
BTW, the details of where and how much are clearly in Wil's signature. He is in NSW.
Back on topic, Wil I would love to get a shoot of the Stagea done sometime soon. Will PM you when I'm ready. As I've said before and will say again, they look awesome!
will pm you dark.
Just received the prints :yes:. They turned out awesome (if I don't say so myself). Excuse the jpg compression on these photo's of the prints.
The detail is amazing. You can read the stickers on the wheels of the white gtst, see a couple of tiny bugs on the GTR, and see a hairline crack in the lower part of my front bar.
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
