SORRY guys i didnt make it, i had my alarm getting installed today and as always nothing gets done on time.
i was shattered and i still have to wait untill tuesday for the alarm.
Is it bad to use my 19s???? I thought the bigger the wheel the more faster you go?
oh yeah i also have a apexi pod filter, if that helps.
Edited by Tough R34
If that is a serious statement i better set the record straight.
The bigger the wheel, the heavier it is, also the more force/power needed to get it moving. Due to the small profile there is no give in the tyre, thus will break traction more easily. 19's are just for show, they are bad for everything else. I am not bagging you as i also have 19's on my Skyline.
The Apexi pod will not improve anything until you are making over 230rwkw, that's where the std air box becomes a restriction. In fact your pod is probably loosing you some performance, as you probably have it open in the engine bay, free to suck in all that hot air. A pod always should to be enclosed in a custom box with a big cold air feed, from the front bar.
Hope to see ya next time at Calder
emsta: Calder Park Rwy, is just off the Calder Fwy, near Taylors Lakes, Hillside, etc., just before Sunbury.
On a Friday night, it is $20 to spectate and $55 to enter your car. To compete you will need to where long paint, long sleeved top, runners/shoes, and a Helmet (which can be hired).
NICE BURNOUT
At first i was like "WTF is he talkin about" Then i looked at my post :)
PS: Thanks ;) Compliments of DECA skid pan.
If you are going to buy rims, you'd be better off buying a set of 17 x 9 for the rear. I have a set of 4, 17in rims for sale (mis-matched pairs, great for drag, drift and drag ;) ), rear are new and only been used twice, fronts are s/h and in good condition, $300 for all 4, no tyres :P
Had to upgrade due to my latest Brembo brake upgrade :D.
SIF 17's are best
smaller the better, more sidewall, more flex, more traction
i has R33 wheels if you want... provided Ronin aint gonna borrow em, crap rubber $150... but yeah... Ronin has dibs if he needs to use them to move his car around :)
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
