Hey Everyone...
Looking To Sell Both A Aftermarket Blitz BOV And Piping For A RB25 And Dash Cluster (130,000)
Both In Good Condition/Working Order...
*Blitz BOV And Piping - $200.00 Neg
*Dash Cluster -$150.00 Neg
Pictures available upon request...located in sydney
Thanks
https://www.sau.com.au/forums/topic/121932-r33-s1-aftermarket-bov-cluster/
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
