  • 1 year later...
needed: r33 stock turbo in good cond.
Hey
There is a few in Melboune at the moment. I was looking for one for ages and managed to find a few.
Have got one already so I will PM some details of people who have one.
Thanks,
Abu
https://www.sau.com.au/forums/topic/122186-r33-stock-turbo/#findComment-3260815
I have on in the for sale section right now if you look :)
Saw yours man, personally think you are asking a little bit to much for a 2nd hand STD turbo.
But you have a right to advertise as you please. Good luck with the sale! :)
Thanks,
Abu
Edited by abu
https://www.sau.com.au/forums/topic/122186-r33-stock-turbo/#findComment-3261530
Wouldnt be the first time one has sold for that much and certainly not the first time I've sold a stocker for more than $400.
Good luck - all the best.
It's there if you need it.
Adrian
https://www.sau.com.au/forums/topic/122186-r33-stock-turbo/#findComment-3261578
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
