Again sorry for asking but i have noticed that my R32 GTR has what i thought to be QF45 AFM installed on it.
I thought that the part number for these is A36-000-P60.
When i checked mine it had a part number of A36-000-J60 are these suitable for my car as i have no idea if this could be effecting Air fuel ratio's.
regards
https://www.sau.com.au/forums/topic/122338-afm-part-numbers/
post-28646-1150341290.jpgThat is a good question!
Yes it runs fine but i know these were just put on when i got the car. I think i will just be safe and will get the air / fuel ratio checked later this month as i am still waiting for my 320kmh speedo to show up before i run it again.
Are they the correct type to be running? or should i just get other as i dont know if these units are speced to operate in the correct voltage range and it is worrying the crap outta me that they are wrong for the car.
Edited by tacker
yep, that's an rb20det afm
it's not the correct type of afm, to run it properly, the ecu needs to be remapped. If the car runs fine with no noticable problems, then it probably has been remapped or has a piggyback ecu of some description (eg. SAFC, emanage etc.), or full aftermarket computer.
get it on the dyno asap to check your AFR's (it's a good idea anyway once you buy a car to check afr's), but if it's running without any noticable problems then you are probably ok.
how is it set up with the single afm? are there still 2 intakes and one afm on one of the intakes and no afm on the other? or do you have a single intake system setup? or do you have 2 x rb20det afms?
rb20det afm's are better than rb26dett afm, so it's probably been done to allow for better piping.
Edited by MerlinTheHapyPig
Merlin,
thanks for the help i really do need it.
No is has 2 of the buggers still in the orginal positions i would hazard a guess.
The car pulls like a train and to date it has not given me any problems that i know of. But as you say i will try and get the air / fuel ratio checked which is not easy to do over here as no one knows much about these type of cars. Would be heaven if i could get Pfc and have it tuned but its not to be in this part of the world.
The ECU looks like its standard to me but the seals have been opened .
regards
Merlin,
regards
getting A/F ratio checked shouldn't be too much trouble. Just go to anywhere with a dyno and ask for a "power run with AFR printout". They will put a wideband o2 sensor in the exhaust and log the AFR while doing the power run.
I'd say it's been remapped. If they handn't, you'd probably feel it driving, if the car would even start at all. Maybe ask the previous owner what he did?
This is probably good! it means your car probably have a tuned ecu, and rb20det afm's are much better than rb26dett afm's
but in any case, unless you can find out from previous owner, go get a dyno run asap.
Merlin,
I will make that the first this i do when i get to install the new speedo.
I have no chance of tracking down the old owner as it was brought from a huge import yard, about 10,000 cars there. But now that is mention it run like crap for the first few hours but came good after that. Could that be a piggy back ECU in learning mode, as i know these AFM were installed after i showed interest in it. Could i be that lucky to re istall the RB20 AFM if it was mapped for them ?
http://members.dodo.com.au/paul/
documents;
Nissan OEM Airflow Wiring Diagrams;
covers the common models and sizes and wiring
if someone can kindly send me a gtr rb26 afm ill post it up (need pic and wiring/pinouts)
Nope they are green and 80mm id so i reckon they wil be from RB 20. Which is ok just a long as they are calibrated to run on a 5 v signal. I will then have the air / fuel ratio checked ( hopefully ).
just a question i noticed their was a K band trim on the ECU would i be right in saying this is for adjusting the fuel.
Regards
  • 1 month later...
was looking for the wiring diagrams for the Q45 as i just got one for my car
once again Paul, awesome site you have ..
thought you might wanna add that
apexi pod model 500 - A021 fits the Q45
and 500 -A022 is for Z32 and std skyline 80mm AFM's
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
    • GT-R clearly the better choice! The 300 is certainly not insaly fast but has a decent amount of poke. Does a nice little drift around the corners with a decent amount of throttle. It's VERY predictable in a slide too.  Feels so progressive! People probably presume there's a 25 year old driving it based on my behaviour this week! 🤣
    • Yeah Jap import. Fairlady Z then! I'm a bit the same.  They've been on my radar for a fair while but then just impulsively decided to buy one!  Was going to just buy an NA and add turbos to it later but decided to save the f'ing around and just buy the turbo version.
    • Thanks mate, well done to you too! Yeah not looking forward to doing any major work to it!
