the ford rs2000 held the record in the late 80's early 90's. the current record for 0-100mph-0 is held by the a Ultima GTR (no its not a nissan) at 9.8 seconds. we previously held by a ferrari enzo at 10.9.
  • Replies 71
Posted Images
Electric cars aren't gay. Have you seen that new Lexus forget what model it is, but's a big v8 with electric engine as well and it goes so damn hard and quite good on fuel for a big v8. They look awesom as well.
I'll try and dig up a website on it.
Its a V6. 'Power' of a V8 with 'economy' of a 4cyl. But its MILES better than that pyruis thing. Or I think so from what I have read and seen so far.
I still dont get this 100% though.
So car A travels 100m to get to 100kmh and takes 10 seconds
Car B takes 50m to get to 100kmh but also does in it 10 seconds
Is that it?
Im trying to get my head around that... Can someone explain it differently please.
Basically
When talking 0-100kmh races, the 'KMH' is the Constant and the 'Distance' reached varies.
When talking 400m races the 'Distance' is the Constant and the 'KMH' reached Varies.
Simple......
Edited by PSI_GTSII
Is that it?
Imagine Car B is REALLY laggy, and only does 10k/h for the first 9 seconds, then for the last second full boost comes on crazy hard and it flys from 10k/h to 100/kh in that last second, the first 9 seconds it only covered 40meters because it was going so slow, then the last few metres it speed up to 100k/h..... covered it really quick..
(maths aren't right there just trying to make the point).
Is that it?
Think of it like this. Both cars accelerate for 10 seconds. Car one accelerates very quickly to almost 100km/h in the first one second, then slowly accelerates to 100km/h over the next 9 seconds. It spends most of its 10 seconds at high speed. Car two accelerates very slowly for the first nine seconds, the quickly accelerates to 100km/h at the end. So it spends most of its 10 seconds at low speeds.
Both cars will reach 100km/h at the 10 second mark, but car one will have travelled more distance because it has spent more time at higher speeds than car two, so the AVERAGE speed over 10 seconds was higher.
This is an extreme example, but it applies to real world situations - a more reallistic example might be a stock GTR (all wheel drive) and modified GTST (rear wheel drive). These might have the same 0-100km/h time of 5 seconds, but the GTR will launch harder, and will hence get ahead quickly and cover more distance before the 100km/h speed is reached.
If that makes any sense to anyone...
Edited by Big Rizza
"but the GTR will launch harder, and will hence get ahead quickly and cover more distance before the 100km/h speed is reached. "
Shouldnt it be,
but the GTR will launch harder, and will hence get ahead quickly and cover less distance before the 100km/h speed is reached.
Or perhaps i do not grasp this concept real well? :P
Shouldnt it be,
The GTR will launch harder, so it will be ahead of the GTST. The leading car will have covered more distance than the trailing car (otherwise it would be behind the other car, right?). Therefore, the GTR will have covered more distance than the GTST, and would be leadin the race. The GTST accelerates harder than the GTR once its tyres hook up properly, so it manages to reach 100km/h at the same TIME, but the GTR is already ahead by several car lengths after the brutal launch, so it has still covered more distance.
Edited by Big Rizza
im not so sure about that last example in this context, the initial example is simplified and is correct and interesting but it fails to model traction off the line, it assumes all have perfect traction
that last example of the gtr vs gtst attempts to incorporate traction/launch and is confusing peoples :P
So what your saying Big Rizza is Torque wins races. :P
To some degree yes. All else equal, the torquier car will win. But just as power alone will not win races, torque alone doesn't win races either. The Mazda Bravo turbo diesel I occasionally drive for work makes more torque at 2000rpm than the RB20DET powered Skyline I own makes at its peak, but with a peak power of just eighty-something kilowatts at 3500rpm, there's no way it would keep up with the skyline.
The turbo car runs a 16.3 at 265.69km/h (see what I mean about unreallistic :P)
This is only because your turbo car's speed increases exponentially (ie. it keeps accelerating faster and faster the more speed it piles up) - a parabola doesn't even come close to modelling a turbo car's speed over time :P it might be right initially because of the wheelspin but it won't be right afterwards.
Im still really struggling with this hey. I'll work it out when I get home. I think I got it. I just need to get my head around the whole dont work out out with speed and time, work it out with DISTANCE and time.
Thanks fellas. This really should be basic for me. :P
Which leads me on to...
AVERAGE POWER!
Throw that Mazda Bravo behind a CVT trans and it might be a different story. :P
But yes as I've said before, its the complete package that matters.
Power, gearing, weight, traction and driver. :P
Well, if you don't like it, ignore it! :P If the original example works in your head better, use that!
Edited by Big Rizza
I DID say that extrapolating the formulas I chose wouldn't be reallistic :P It is just as unreallistic for the family car, which accelerates at a constant and linear rate for all eternity.
AVERAGE POWER!
Power, gearing, weight, traction and driver. :D
Even with the CVT, I doubt the Bravo would keep with the skyline. The Bravo has a peak power of eighty-something kilowatts as I said, and I reckon that even with gear changes, rev changes etc. my peak power of 160+kw would result in greater average power. Plus skyline is lighter :P .
I understand what you're getting at.
I had an argument in High School with someone about this very thing. Had a pic of the graph you gave and you had to say which car was in front when they all hot 100kms/hr.
It's funny, nearly 90% of people thought they were a the same position! Geeze!
Anyway.....0-100's and quarter miles are good benchmarks..but to get what i think you want, you would like to see a 'How far can a car travel in 10secs..or 20sec' from a standing start (or rolling, or adapt further)
Yeah???
But if you did have that, people could then argue the opposite.. "10sec distance measurements mean nothing, doesn't show how fast it would do a quater mile!" and then show another graph and quote a few formulas.
Gotta do your own research i guess and go from there
:P
..and while I'm thinking about it more (gotta stop soon)
Your comparing apples oranges and lemons.
Everyone here is pretty much apples, apples so it does make sense to compare
Catchya
Birnie :P
Well to me I always thought you could compair fruits.
I mean apple is green or red, oranges are well orange. There is a comparision, its fair... I never understood the problem with it. Thats what comparisions are meant to do :P
    • Thanks for all the replies fellas. Gonna finish putting it back together and see how it handles the set up. If it starts pinging it’ll be parked.
    • Well, I can recommend the partial AV system translation CD I ordered from Car Audio Workshop in NZ. Whilst it didn't address the date issue, it has conveniently translated on-screen menu items into English, and now allows the GPS-received time to be offset in hours rather than minutes, so I can display Eastern Australian time accurately ( and bump it by another hour when daylight savings starts ).
    • Yuh, if it's 45°C outside, my car is driving in it.
    • I'd be curious to hear more. Otherwise, have you driven a modern x-trail? I wonder how it compares. Here in Australia they are/were popular for rentals and fleet vehicles. I have been in some and my impression was they are bad. But, this may have been very different in the 2000s at a good trim level. Twenty years is plenty of time to make the model worse. I do very much agree with the 2 silver cars in the garage approach. But, not driving because it's too hot would not leave a lot of time in the year for many Australians. I don't think you need to worry too much unless the car has actual issues with overheating.
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
