Hey guys,
A few of us from around Hornsby are meeting up tommorrow night for a bit of a drive.
Meet - Mt Colah Maccas 7:30pm
Heading down Bobbin Head towards St Ives and then onto towards McCarrs Creek Rd - grab a bite to eat and head back.
Wont be a late night, just a bit of a fun drive.
Anyone interested?
See you there!
:D
Chris
https://www.sau.com.au/forums/topic/122378-friday-night-16th-june/
If I'm around / not still at work I'm a maybe
Might take the highway though my car dosen't seem to stick to those roads too well...
Ricky!!!
Thats cool mate - We can wait for you!!
just wait for us though at the end of bobbin head road ok??
:devil:
You know you want to James :ermm:
:thumbsup:
f**k I'm even more pissed off now.....james just made the car the way he wants it and was starting to reall enjoy a good thrashing... makes me so sad!
james if you still wanna come, you can ride with me... it'll be better getting out and getting your mind off it!
It was a pretty nice clean run, for the bits I did make. It was a good night for it - all that cold made for great throttle response.
I don't think I bottomed out through McCarr's Creek Road, which would be a first.
yeah it was a good nite its a pitty more of the sau's dont come on them.
i love our little hornsby cruises... I've got some good mates I usually cruise with.. although haven't for a while... i should call them out one day for a run!
yes Liz, yes you should
Also - I've got a few mates with other cars who are keen, a good mate of mine in a VU SS 50 ute - this thing...well....its blindingly quick and the handling - 2nd to none. another mate with a 500hp 300zx, just to name 2 :)
My new brakes and suspension is going in to the car this week, so if there's another run on this Friday I'm keen, but I'll be taking it at the same pace as last Friday whil I run the coilovers in.
Chris - some of the guys last Friday (your mate from Mudgee at least) has never done the Commenara Parkway. We should rectify that. :) Unfortunately there are houses facing on it, but its a lovely piece of road.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
    • The video for the servicing and fuel filter change can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44 One of the main jobs I wanted to do before the car officially went on the road, was to remove the awful looking blue silicone hoses. There's nothing wrong with having coloured silicone hoses, but I realise as I'm getting older I prefer monotone engine bays with a splash of colour on the engine cover(s). I cover this in a lot more detail in the Youtube video, so unfortunately there's limited photos of the process. The intercooler, upper radiator, boost vacuum and upper breather hoses were all changed to black silicone with mikalor clamps. The only blue left is a blanking cap at the back of the inlet manifold and the GReddy pulleys (which will be replaced for stock when the cambelt gets replaced) While the intercooler pipes were off I gave them a quick clean/polish too A before photo I do have a replacement air filter on its way. Fuse box covers were painted blue, they're now satin black Another job on the list while the bumper was off, is to add some mesh https://live.staticflickr.com/65535/54737966256_99b28bfa30_c.jpg[/img] I was hoping to use some thin wire to secure it, but it seems I've misplaced it and the wire I had was too thick to twist easily. I ended up using cable ties for the time being https://live.staticflickr.com/65535/54737131882_c2b7989dcc_c.jpg[/img] Was pleasant to see this https://live.staticflickr.com/65535/54737131627_8b2aab13b3_c.jpg[/img] The last thing to do was to fix the front grill and re-mesh that to match but I ran out of time The Youtube video can be seen here: https://www.youtube.com/watch?v=R4FsF6tgizE&t=23s
