Its only Optimax mate.
So considering what you can buy Martini or Sunoco for (much better fuels) i wouldn't waste my money.
I would run with 95RON and some Martini OB (will bump it upto 98.3RON)
and its a lot cheaper doing it that was as well :)
GMB
I guess you must be aware its difficult for you to post without it seeming that you are just pushing your vested interest...
Wouldn't waste your money..... I would wager that given optimax is less than 25% of the price then Martini or Sunoco would need to be 4 times as good to make it worthwhile, or hey lets pretend you use optimax and a very expensive octane booster, then I'd like to see verifiable results that you get twice as much "performance" from the Martini stuff.
I bet theres no real way to back even the second statement - the pissweak 98 vs M110 comparo test on the website was done with a completely different tune...... Pricing is conspicuously absent from your postings and from the comparos too.
Its one thing to say x product has awesome performance, but surely most people would weigh it against it being 4 times as expensive!
All I'm saying folks is that there are lots of race fuels around, don't just buy one because its new or lots of people are suddenly praising it.....
https://www.sau.com.au/forums/topic/122425-tas-fuel/page/2/#findComment-2283755
:PRIGHT
How is OPTIMAX 25% less than any of the other race fuels???
Last time i checked there was about 30cents difference in it :D
I have run and used Sunoco for many years and always would over OPTIMAX as its a better fuel, have a better combustion rate and is more efficient for the high boost application that i was running.
OPTIMAX just didn't cut it, never has and never will for me!!!
As for the results on Martini OB then if you had a look the info on the first page and on there site you would see the test they did was with the SAME car/fuel but all they did was add the Martini OB, wound some iginition into the mix until they reached the knock level that they already had from the first run.
In the mean time picking up a couple of extra kw's in the process but without actually adding boost to the application.
Skyline_R32_test.pdf
Lets see you do that with other OB's like *&^%$ or *%$$@ or even $%$@(%$@
What i wrote was based on my own personal experince's from tuning my car and the rebroad minded persons that we found/got.
Funny thing is that 2 out of 3 other people with very similar set up to mine had the same results as well.
Dr Drift has done dyno research with many different forms of OB and came to similar conclusions as well and he use's and recommends the same.
SEE A BIT OF A PATTERN HERE???
Now you can believe what you will but i haven't once plugged or try to push anything on SAU (save it for my own site and when i travel) nor do i push with any other of our sponsors.
What i do do is give my opinion (as thats all it is) and try and help out my friends and people i know if i can in anyway, be it good prices on parts, free labour or advertising.
Truth is from 270 views and 24 replies yours is the only negative one (not sure why) and the only one that expresses a different side of the argument.
Have you used any of the above mentioned fuels or OB's personally???
Can you buy it in at wholesale cost and then offer it others without making money on the product???
Have you done any R&D of your own with your car and a comparison test with over 4 different fuels and 7 different OB's???
My point being that i have and the results spoke for themselves really.
Talk to anyone that has used a certain product and they will give you there opinion, speak to the person next to them that has used the same product and chances are you will get a different opinion.
What i wrote about the Martini OB was based on my opnion as it was for the Sunoco/Martini fuel VS OPTIMAX.
If you have a problem with something that is written or if you feel that it doesn't apply to the forum rules then use the report post button.
If you have a problem with another member then try a PM to expain or go through a mod.
If you want to have ago at someone ele's post stating you would like to see the proof, then turn around with a side of your argument without any proof, then save if for BC.com or ricers R us ;)
GMB
https://www.sau.com.au/forums/topic/122425-tas-fuel/page/2/#findComment-2290975
:PRIGHT
It was suggested that the martini fuel was in the region of $147.00/20lt or ~$7.35/litre , whereas optimax was $1.70/litre? More than 30 cents there surely.
lots of stuff about OBs chopped for space
I see a pattern; I didn't mention OB except as an additive to the cheaper fuel. I did get my wires crossed there!
I was comparing the cost/benefit ratio of spending 1.70/l + some octane booster, to spending $7.35/litre, for the average person who lets face it might need more than 95 ron but probably doesn't need full on race fuel.
I also see Martini's website publishing extremely positive testing results from their own testing, reported by a magazine they advertise in! Excuse me for being a sceptic....
The test I referred to was 98 vs M110, not the OB test, and FWIW I think the article makes it fairly clear if you read between the lines that there wasn't a magic 50rwkw in the fuel, more in a decent tune anyway....
As for 95+OB, likely to only see results around the same quality as straight 98 - and I'd have thought a decent OB would cost somewhat more than 30c/litre? I can see its simpler than buying drums though
Out of 270 views and 24 replies it seems your the only person who has used the fuel
No, afraid I haven't, really only ever stuck to BP100, Elf, methanol on occasion and when available have run Powermist T112/T10/Dynol 832/TO137 (powermist fuel is a bit exotic though)...
No to most of the above I'm afraid. Well, haven't with the car anyway, certainly tried running a fair few different fuels in our racebikes over the years. I'll admit I'm new to what fuels work best in a turbo application, and thusfar I'd just stick to what has been shown to work.
As for OBs I'd always tune for the fuel, not for an additive- too risky IMO - anyway, I was only playing devil's advocate mentioning their use
Absolutely true, no argument here.
GMB
I'm sorry if it seemed unduly antagonistic, that wasn't really the idea. Just wanted to spark some debate/verification instead of every 2nd post being "buy martini its great I can get it"; if you follow my drift (so to speak).
https://www.sau.com.au/forums/topic/122425-tas-fuel/page/2/#findComment-2291070
I hear what your saying chief and im not having ago at you at all, as thats your opinion.
Like i said at the end of the day its just people's opinions.
Ive never once said buy Martini i can get it, i just recommended it as i have found it to be the best OB on the market at the moment that i have used :)
As for tuning for fuel and not OB i couldn't agree more, but when you factor in the crappy 95RON Premo :P that we are so lucky to have here in Tassie then most people looking for big numbers would normally use an OB to bump it up to see what they can get.
Having said that for the sake of 10rkw's+ it works out to be a pretty expensive excerise when you have to put OB in with every tank.
I personally wouldn't do it on a daily but have done so with my track car and the boat.
As for race bikes, im not 100% sure if your talking about road/dirt but from all the bikes i have ever owned/raced/riden or worked on i have found that using OB or even Premo in some (most only run standard ULP as u would be aware) it not only fowled the plugs and made the bike run worst, i got less k's to a tank.
Id like to know more about your finding's with bikes, especially if it was road bike :)
And im always one for a good argument myself, jsut remember though that it is the net and what someone writes isn't always the way it sounded in there head, nor can you hear the sacarism in there voice :(
GMB
https://www.sau.com.au/forums/topic/122425-tas-fuel/page/2/#findComment-2291300
Id like to know more about your finding's with bikes, especially if it was road bike :teehee:
Road, dirt, street, race,two stroke, four stroke, singles, fours...Mucked about at some point everything from 1970's 2 stroke vintage MX bikes to GSXR1000 production superbikes; my dad used to own a large Kawasaki/Suzuki dealership and service/tuning centre in Victoria. We (mostly Dad!) raced/prepped bikes for thumpernats, state MX, state roadrace, national roadrace.
My experience is that...
Most roadies do seem to go fine on ULP or PULP, but for race applications and when you're running higher than stock compression sometimes we'd just go straight for the race fuels. Some of the ram air equipped roadies (ZX9R's especially) used to seem to need a dash of isopropyl alcohol to stop carbies icing up, all but fixed with the majority on injection now. And I think now most circuit racing requires non leaded pump fuels anyway doesn't it?
Not to mention that since most bikes are jetted/run plugs suited to ULP/PULP, it takes tuning and mucking around with maps, jet kits, doing plug chops etc etc to get any small benefit on the road out of other fuel; not really worth it generally.
BP100 is more than adequate for most race bikes, two strokes seem to run fine on ULP or sometimes PULP, however on older air cooled race bikes (especially two strokes) we found the race fuels were useful in reducing combustion temps hence temperature related seizing/pinging.
We ran Powermist race fuels because we were able to backdoor it from Team Kawasaki Australia (who were running it in their 750cc superbikes and as I recall were backdooring theirs from Muzzy's in the USA, haha), and the bike it was being used in primarily tended to run quite hot ('97 KLX650R grasstrack MX bike with serious engine mods, i.e. 13.5:1 comp, carillo rod, wiseco forged piston, white bros custom cams, modded head and 65hp at the tyre, did over 200kmh at Finke, radared at 153kmh at Geelong thumpernats - in 4th!) the cooler burning fuel helped somewhat.
Oh, and everything seems to hang together longer running motul oils; can't recall ever having a blowup on motul 2 stroke, and seemed to get better service life out of most 4 strokes with motul oils.
Our 1981 2x4 Hilux shop hack with a tired 18R seemed to go noticeably better on BP100, in fact even when it had 2 stroke oil mixed in it, and on occasion seemed to like the Powermist Dynol832 - you find these things out when you run low on fuel and have a few drums of race fuel in the back, haha.
Edited by floody
https://www.sau.com.au/forums/topic/122425-tas-fuel/page/2/#findComment-2292124
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • BRUH, one of the biggest mistakes of my life..... and i've had plenty ;[)
    • @Murray_Calavera iam just considering options 🙂 of course it is very expensive so that why i ask here 🙂  @joshuaho96 I looked at that GCG hybrid(i remember looking at it few weeks before) So this is "that" hybrid where i send them my turbo and they upgrade the inside to Garrett stuff and then they send it back. It cost around 1200-1300 USD which is FAR cheaper than the HKS and it is what iam looking for(i just do not have experience like this...to send something off to "upgrade" ) @tylink720 that is like 150 USD turbo no? 😄 I dont think i have the "ease on my mind" with this kind of turbo. I just put over 7000k USD to "LINK" up my engine...dont want to blow it up with cheap turbo 😄     EDIT: https://www.cj-motor.com/gcg-turbo-charger-for-nissan-rb20det-rb25det-high?srsltid=AfmBOooVeOZ6CZ6r1AIv5m-KPaa6BvudIPJTY8LW78khkd-gQlsaCht9 I looked at this and it seems ok? It is that CGC hybrid and it costs around 1250 USD (with back shipping). Do any of you have experience with this hybrid on NEO turbo? I quickly look thru the forum/web and it seems very good.
