Was down at the local Hardware House today and discovered an isle of Engine Bay spray paints.
I found a nice colour for $10 and spent the afternoon spraying bits n pieces. (including all over my hands and finger nails LOL). I was quite happy with the result as im not a car person and never taken bits n pieces off an engine before let alone spray painted everything.
Hopefully the paint will last atleast until next weekend :( coz I quite like the look of it even if it is just myself that knows. Its often the little things that count I always say.
All up it took me around 4hrs including drying time (3 coats) to do the job. Would have been quicker if I had the correct tools grr.
I want to get braided lines next to tidy everything else up and then i'll be close to happy with the engine bay. Can anyone recommend an online store for these parts or even just for info/pricing/measurements etc?
Fullsize pics can be found at http://skylines.pnc.com.au/pics/ben/gold/
https://www.sau.com.au/forums/topic/12248-spray-painted-engine-components/
Just some engine heat proof spray paint that was good for metal or plastics. I forget the brand but their was about 100 cans to choose from ranging from like $10-16 depending on brand and can size.
Looks good Ben. Nothin' like getting in there & having a go. Dunno' about painting the rubber intercooler hose joiner though? Go get yourself some coloured silicon boost hoses( red,yellow,blue) it's a tad costly but looks great.
A few different places.
Autobarn (in Mild End, Adelaide)
ASE
Morpowa
The latter 2 are performance workshops in Adelaide.
It comes in numerous colours, is much easier to route than standard rubber, & look ok :) Not cheap though!
4mm ID - $11 per m
6mm ID - $17 per m
8mm ID - $22 per m
Approximate prices.
GCG in Sydney stock the stuff, as would a number of places up there I'd imagine.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
