you can thread the wires up the pillar pretty easily. just remove the kickplate and the cover on the side of the foot well, then remove the rubber from the door frame. you can slide the wires up the side of the A-pillar cover and out the hole from the tweeter cover.
stock split wires come together deep in the dash. Dont bother to use them mate, they are pissy wire anyway.
As terminal said, I ran my tweeter wires up behind the kickplates, then between the dash and the body and up into the A-pillar.
woofer(meaning, for splits) wires I just used the stock wires...i know, but i cbf'ed to replace em.
My amp is also under my passenger seat. Just remove the stock airvent under there and run the wires through there. I put some MDF below the carpet and drilled/screwed the amp onto that.
  • 1 year later...
all i did was flick out the cover with a screw driver. unscrew the stock tweeter.. throw that sumwhere ull never find it. run your new wire down tha a piller. n poke it out on the door side.. poke it behind the dash with a screw driver, mount your cross over under the kick panel on the drivers side and ecu cover on passenger side. stockwires for woofer.. jsut take out the door trim (yes there is a screw in the bit that you pull on to close! (tooke me a while :banana:) then i just pulled out the head unit worked out what was the front speaker wire head unit to amp imput on x over. and what that was connected to goes to your woofer out put on the x over. took me like hr n half 2 hrs to do a semi ligit job... also i did mine in pares like both the tweeters mounted, both the woofers mounted, etc etc gd luck
that looks SICK! well done ! and woulda saved a HEAP of time
I am going thru the epic stereo install from hell at the moment haha.. I am just worried I didnt give em enough wattage- 50w RMS all round - I have the Hertz 165's too - so hopefully that gives them enough power
what i did with mine....
  • 10 months later...
I put mine where the stock ones came. I did not have stock ones come with the car, so i drilled holes and put there in there.
To remove that A pillar part, you need to do the following (easiest this way)
- Remove front seats
- Remove door sills/kick panels
- Remove the covers for the seatbelt things
- Remove A pillar thing
Trust me when I say, this is NOTHING compared to removing the rear bar! Just a quick run down of the rear bar
- Remove boot carpet
- Remove holders/plastic caps etc
- Remove plastic from sides
- Remove wall carpet
- Remove rear bar
That takes about 2h, compared to the A pillar ~30 minutes.
In my system, I LOVE the tweeters placed where they are. My Hertz HSK165's are splits, with woofers in the doors and tweeters on the A Pilar. As there is no midrange speaker, the balance is made via tuning the EQ.
Hertz does actually stock midrange speakers, but not on the RS4.
If you want a comment on my sound systems pumpage, I honestly dont think it could sound any better than the way it is, ask Ian, aka humble.
i was skimming over this to see how to get the a pillar plastic off and just had a question. why does the seat need to come out??
thats what mine have, needs more :laugh:
Both AlexCim and myself mounted amps under our seats :D
my stock system still running the stock amp but aftermarket head unit, no need to upgrade my system.
unless it was done in japan ? cause it pumps pretty damn good ;):banana:
and no room underseats for amps, got electric heated seats.
so i saved myself about 800bucks in speakers :D HIGH FIVE!
    • Hi from Canada, Both of my calipers are starting to fail. My car is a 2005 M35 Stagea ARX and I can't seem to find any parts or any cross reference caliper that would fit my car. Is there a company or a similar caliper that would fit and I could replace the OEM one. Or if anyone knows where I can find a new OEM. Any help is very appreciated. Let me know!
    • Maf is a question mark but TPS  I have set at 0.47, the fact that I’m getting proper voltage range out of it with the key on leads me to believe it’s functioning properly. I’m getting proper voltages on basically everything. I still need to look up voltage ranges for z32 maf and test that
    • Honestly no not at all, but it’s a very basic tune, it’s stock injectors q45 tps and z32 maf. Other than that it’s a completely stock base map. The file is from nistune and from my understanding if it was tune related I would be able to unplug maf and tps and it would still start even if it was a really shitty start. I have tried starting it with coolant temp, maf, and tps unplugged none of those 3 togethor or individually changes anything
    • 🏆 Skyline Supremacy Meets Mount Panorama Magic 🏆 Join SAU NSW as we take the long way to Bathurst, the home of GTR greatness. Saturday 30th August 2025 7:00AM Meeting Hanna Park North Richmond 7:30AM Departure Cruise Via Bells of Line Road 9:00AM Arrival to Stop 1: Golden Poplars Meadow Flat 9:45AM Arrival to Final Destination: Mount Panorama Motor Racing Circuit Meet Location: Hanna Park North Richmond Stop 1: Golden Poplars Meadow Flat Final Destination: Mount Panorama Motor Racing Circuit   *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • What does it look like with highway driving? And yes, I had a similar thought as Duncan. It looks quite similar in my Stagea and I have made myself accept it as normal. Might have to look into it some day   Highway gets as low as 10l/100km on my end so I'm not as worried about it being a mechanical issue. More likely just the tune on the haltech.
