hey guys, ok i went away for a week and a half came home and my R33 gtst wouldnt start the car was perfect when i left. came home had no power at all, tried jumpstarting it, got power to everything but when i tried to start it, it made a ticking noise for a while then nothing, tried a couple of times and got the same result.
Next day went out same thing no power tried charging it, still nothing, then i had power to everything tried starting it got nothing all my lights work everything but wont turn over it stopped making the ticking noise but still wont turn over, i checked my battery that fine, tried tapping my starter did nothing. all fuses are good spark plugs are good.
NEED HELP ASAP, thought maybe it had something to do with my imobiliser, but doesnt seem to.
i heard u cant put a starter from an auto into a manual is this true?
what else can i try...
https://www.sau.com.au/forums/topic/122605-r33-wont-start/
Ermm. Sounds like your battery died.
Either:
It has a tiny bit of juice to work the lights, but not enough to start. The clicking noise is usually the solanoid that pushes the starter gear onto the ring-gear (or whatever manuals have)
Or:
Did you jump it from the battery in the boot, or off the fusepanel under the bonnet like you're supposed to? If you have a good battery, but still nothing happens, you could have blown your starter motor fuse. Check that fuse.
Either way, if the battery died after a week, it's time to replace it.
https://www.sau.com.au/forums/topic/122605-r33-wont-start/#findComment-2264876
chances are its your battery as RANDY said.
to get it started keep the car thats jumping you at around 2000rpm with all electrics off (radio, lights etc), give the battery time to build up some power then turn it over.
i bought a new (cheapo) battery after the first time i got my car on the road after the first rebuild, 2 days later i took it off the road (didnt disconnect it) and 2 months after that i tried starting it and not only was it a complete c**t to start, it wouldnt turn back on if i turned it off.
moral of the story - disconnect your battery if you're not going to drive it for a while, especially if its crappy/old.
https://www.sau.com.au/forums/topic/122605-r33-wont-start/#findComment-2265197
i got the sameproblem mate, wqent away for the long weekend and left my f***n light in the car on, the car didnt start , even with jumper leads from a barina the car was making a ticking noise but just wasnt turning on... i had a 6 month old battery so the nrma came and jump started it with a high powered battery,
my guess is skylines need alot more power than normal to start????
https://www.sau.com.au/forums/topic/122605-r33-wont-start/#findComment-2265947
i took the battery out and put it in another car and it worked perfectly, and had it tested so i know its deffinatly not that.
i checked the fuse's there all good.
You're talking apples and oranges. A half-dead battery that couldn't start a V10 Viper would have little trouble coughing up the CCAs to start a Toyota Echo, if you follow what I mean.
What voltage do you have on the battery? How did you have it tested? The only reason people are pushing the battery thing is because all your symptoms are the same as a dud battery.
The only other potential cause could be your immobiliser. Depending upon the model, it may be built to detect a loss of power and shut itself down (ie immobilise the car). It's a long shot though as you've already said you can hear the starter solenoid firing...
https://www.sau.com.au/forums/topic/122605-r33-wont-start/#findComment-2266498
    • Just bought a 2002 Stagea 250tRS VR-X Four AERO VQ25DET and spent the last two weekends cleaning and detailing it.. still have to do the wheels and the engine bay but the rest of it came up nice. Imported 2011 to S.A. and I'm the third owner since it was imported. I met the guy who brought it over, he went to Japan and picked out the car, bought it and ordered the wheels. He also gave me a list of stuff he did to the car with receipts. Coil overs (I have the original springs), 3" exhaust from the dump pipe back no cat, Custom dump pipe,(I have the original exhaust), Plenum spacer, 18" custom Work XSA wheels (need restoring, I've made a start..), Shift kit put through the 5 speed tiptronic auto, TV and menus/screens changed to english, Australian DTV tuner installed in rear. I've just had four new discs and new pads as well as all the fluids including the brake fluid replaced. I have all the receipts for the last 15 years and the import papers in a nice folder. Car looks great, goes like hell but fuel economy is not a thing lol.. pics next..
    • I ended up in this rut again lol, and used a shit ton of filler. One thing I can't understand is, even after using a big long block and going in long X pattern strokes, I always end up at bare metal again with no filler, and my repair started at one end of the door and now I've chased my tail to almost the other end of the door. I was thinking of hitting the panel with a hammer where it might be a high spot and making everything low then filling it, I did this on a small section on my other door by mistake and I think I fixed it lol. Is this a bad idea? The other thing is with guidecoat, whether it's the powder or spray, after I sand all the guide coat off, it doesn't reveal anything for me in terms of high spots and low spots and makes it especially hard when it's bare metal (at least in powdered form), am I doing something wrong here, or likely a high spot I keep going over and creating valleys? Lastly, stupid question but, is it possible that after sanding if I only sand over the filler area where I know to be a dent that it's impossible for me to dig into that dent? Unless there are other problems which I missed.
    • Yeah the rule of thumb with an LS is 7psi per 1000rpm. That is decidedly not enough at 6800rpm. I mainly looked for the scenarios where knock started to be picked up and it was later in the session when things were hotter, and oil was thinner, and the pressure was lower than it should be. (i.e very horrible). I am hoping with thicker oil (I was running Penrite ten tenths 10-40, the manual specifies 10-30) that does not leak that it's much improved at that time!!! I am using Project Mu Club Racer CR pads. I'm also using the Project Mu 335C fluid. The symptoms imply that it was fluid that boiled, but no bubbles seemed pretty weird to me when I bled it today. I want to try Castrol SRF as it has a much higher wet temp but, well, I have new Project Mu fluid lol... so I should at least use that. The pedal on track was really noticable. It went from basically normal feeling to instantly near-floor. The car did pull up as before, it was just very much nearly at the floor before the brakes engaged. At that point I pretty much decided the day was very done, it did *kinda* come back during that very slow cooldown lap into the pits. Felt perfectly fine driving home.
    • f**king around with the bro
