  • Replies 67
Posted Images
i also just noticed that you said its a rb30et bottom end, if thats true then having a turbo bottom end with that head i possibly think could be worse than a bog stock rb20, i know its a big call but i think you could've wasted the little money you spent!
They have different compression pistons.
cheers, andrew!
Rb30et is 7:8:1 and rb30e is 9:0:1, he said he didn't touch the bottom end so that leads me to believe he is going to be a tad dissappointed with what he has!
the rb30 et block has oil squirters to cool the pistons.. the rb30 e does not.
Where did you hear this culater?
I've seen both a turbo and n/a block and they were identical apart from the pistons.
I bought the n/a one sitting next to it for $150.
I remember it was mentioned some time ago by some one who confused the bore/rod squirters or what ever they are called with the piston crown oil squirters.
The bore/rod squirters squirt oil on to the load side of the bore.
Not sure of the exact terminology.
the rb20 head has a smaller chamber but has been cc d it also has the turbo et bottem end so it should not be 7.8.1 it should work out around the 8.5 -9.0.1 witch should be great just gotta finish painting my bay then motor goes in and car goes down to boostworks
: >_< I'm afraid you've got it round the wrong way buddy, having the turbo bottom end with the turbo pistons will lower your compression, not raise it. I'd be guessing somewhere round the 7:1 mark which should be interesting to say the least!
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
